Ungas
double tire dati pero pinalitan ko na ng single tire sobra kasing liit 13" lang yata parang sa kotse lang yung naka kabit dati kaya pinalitan ko ng single tire pero mas makali.
Try ko kung mas ok yung adding blokcs nalang but I really need to increased the loading capacity..
maliit ang gulong dati pero double tire.. do you think hindi kayanin ng bearing??? di bale andyan ka naman pag nasira bearing sayo ako kuha ng advice na pang palit
Mr. President any idea how much it cost.. yung new set of leaf spring
meron po ba available locally na leaf springs ng mga toyota dyna?
perfect match po ba ito sa strada?
or any idea kung anong leaf ng ibang rigs ang mag mamatach sa leafs ng strada to give it 2 or 3 inches lift? malaki po ba magiging savings nito...compared sa bibili na lang ng arb or other after market lifter spings?
i pa SOA mo na lang. you wont buy pa new springs gastos mo mga 1.5k lang siguro. but if you really want to change leafs, it doesnt matter for what car as long as the length is correct, the width and the hole for the center bolt is of the same design as the strada. some centerbolt holes are not in the middle exactly so you must first have to determine it. then you will need longer u-bolts and centerbolt, spring clamps if you will just add a leaf.
Invest in a good set of shackles and shocks to improve lift. SOA setups will literally give you 4-6 inch lift. While the IFS is max on 2 inch, you will have to invest a stash of cash for a down kit to be able to compensate for the rear lift.
Ibababa nya complete IFS, these are blocks, extended arms & bush kits. Although dipende sa brand at uri ng sasakyan. Meron yung iba brackets lang para sa front arms lang.
