tik-tik-tik upon 1rst start in the morning pero kung medyo mainit na yung makina mawawala naman, ano kaya ang problema. my car L300 4d56 Diesel Engine
Baka adjustment ng valve tappets.
Usually kasi kapag uminit iyan (and nag-iba na ang size ng bakal), nawawala na din.
Hindi ko na lang pinapansin. Pero kung mainit na ang engine at nandun pa din ang sound, i-pa adjust mo na.
battery or starter
may heater plugs din ba l300? pwedi rin yon
pwede rin baka bomba......anytime pwede sumabog hehe jowk jowk
kidding aside check the 2...nangyari na sa jeep ko yan service lang yung starter or pwede mahina na yung battery.
ok lang tik-tik-tik... masaka kung tik-tak-tow :D
tappets nga malamang. pa-adjust mo na lang. make sure alam mo yung specs ng tappet clearance. saka gagamit sila ng feeler gauge. baka tantyameter lang gawin nila using flat head screwdriver e lalong magloko makina mo.![]()
Normal lang yan, lahat kasi ng engine oil nasa ibaba pa just after starting the engine in the morning. Wait for a few seconds before the oil is distributed by the pump. By this time oil has seeped thru most of the engine parts, kaya nawawala na yung tik-tik sound.Originally posted by acenie
tik-tik-tik upon 1st start in the morning pero kung medyo mainit na yung makina mawawala naman, ano kaya ang problema. my car L300 4d56 Diesel Engine
Pero kung matagal nang umaandar ang engine, at may tik-tik sound kang naririnig, tuppet adjustment muna. Pag hindi nawala, rocker arm, cam lobes failure.
hehehehe tiktik magazine....
nauna pa kay xerex yon ser olivedrab.
meron pa ba non?
oops OT na....
normal nga yon sa umaga sa mga diesel engines lalo na kung medyo luma na....
tappet adjustments yan kung kahit mainit na yung engine eh me tiktik sounds pa rin....
Diba relo ito? bwehehehehe!!!Originally posted by 5Speed
eh kung tik tak tik tak tik tak???![]()
e kung nakapatay ang engine tapos meron tik------tik-------tik na sound? yung sa gu patrol a/t ng friend ko meron ganun na sound, pati yung pizza pie lancer namin dati meron. yung patrol ko wala naman ganun na sound.
Signature
boybi normal lang yan.
It's just the exhaust sytem cooling down. Yup, ang ingay niyan sa mga Lancer. Must be the metal they use.
sir otep, bakit yung L300 ko ay may "tak tak tak" sound? Nagpalit na kami ng camshaft, Ipinaadjust na yung valve clearance, nagpalit na rin kami ng piston rod bearing. Check namin yung pin at bushing, ayos naman, ayos din yung main bearing. Pero after overhaul ng engine ay naroon pa rin anf tak tak tak sound.
Nag overhaul ako niyan before i graduated last month. May left and right silent shaft yan baka yun lang ang umiingay. Kung yon wala naman major na pwedeng masira kaso nga maingay lang.
islandrock,
Nasa left at right bank ng block. Ingrated siya sa loob, pinapasok siya from the front and it is turned by a belt. Siya yung bumubukol sa side ng block. Nasa loob ng timing belt cover sila nasa ilalim ng timing belt. A nice tsikoter sent me a manual kaya nagawa ko yung overhaul at napag aralan ko rin ng mabuti.
thanks 4JGtootsie.
Dinala ko sa calibration at pinatseck yung injection nozzle at valve clearance. ok naman. Sabi nila ay probably yung silent shaft ang nag-iingay. Ano bang future effect nun sa engine kung maingay na yung silent shaft? thanks again.
