Results 1 to 10 of 32
October 22nd, 2003 09:54 PM #1
tapos kakabitan ng remote control? meron kasing may kursunada sa bilstein shocks ko. di ba ito madaling masira kapag madalas kong i-adjust ang setting?
Signature
October 22nd, 2003 10:05 PM #2
Rancho has had enough praises for its adjustable gas pressures. Most 4 wheelers have used this brand, and they have no complains about it. One that I heard though, oil tends to leak out sooner when you adjust it too often. And remote adjust isn't that good in their reports.
Naka-Bilstein ka na maghahanap ka pa ng iba?
October 22nd, 2003 10:14 PM #3
na aliw kasi ako dun sa remote control nya. nakita ko yung sa isang friend ko nakakabit sa frontier. pero hindi ko na-try i-drive.
high praises kasi sya kapag naka soft yung setting. pero kapag high speed cruising na daw, dapat naka set sa mid dahil maalon na daw.Signature
October 22nd, 2003 10:23 PM #4
You only get the variable setting options other than that wala na. Btw, setting 5 has the same stiffness as an oem shocks.
Tsikot Member Rank 5
- 3,144
October 22nd, 2003 10:27 PM #5ang alam ko si woodfire dati naka rancho 9000 ang pajero nya, nagsawa yata at pinalitan ng bilstein. he he he
October 22nd, 2003 10:29 PM #6
bakit kaya sya nagpalit ng bilstein? sino pa bang naka rancho9000 dito?
Signature
October 22nd, 2003 10:31 PM #7
Kaya ko lang bilhin Rancho 5000, hehehe. Alam ko si kimpOy ka-Rancho rin yan! :D
- Jan 2003
- 68
October 22nd, 2003 11:24 PM #8I use 9000's on my Samurai and I'm very pleased with its performance. The soft setting is great when doing slow offroad sections that require articulation. The harder settings are great when playing "rally driver" on gravel road. The highest setting is really most beneficial if you are towing because it helps minimize squatting and it is definitely harder than oem shocks in my case. I guess it also depends on the weight of the vehicle. As for oil leaks at the shock base. This is usually caused by improper fitment of the air hose into the valve. It is not normal for the shock to leak even if you constantly adjust your settings using the onboard kit.
In my experience though, after the novelty is gone, one usually ends up keeping it in a setting that is comfortable in most situations. In my case, number 2. Just my 2 cents.
October 23rd, 2003 12:33 AM #10
Boybi-text me if you cant find it there I know the distributor of Rancho. BTW the new Rancho is 9 speed adjustable comapred to the old 5 speed.
Naalala ko iyong 2013 SJ Forester ng relative namin. FMC change siya ng time na nakuha sa casa. ...
Yaris Cross 1.5 S HEV CVT vs BYD Sealion 6 DM-i
