Results 1 to 15 of 15
    Jan 1970
    Mga experts.. tulong naman... paano malaman if may problema na timing belt mo.. any sound or any changes sa takbo ng car.... Saan ba pwede ma check visually withoug going to a mechanic. May strange sound din ba pag sira na yung timing belt or kailangan na palitan..? Ano po bang parts ang nasisira if me tama na ang timing belt... immediately po bang nasisira ang parts pag wala na ang timing belt..
    My ride Pajero Intercooler Turbo with 4d56 engine.. 78K na ang reading
    thanks,
    marwen
    Dec 2002
    The only way to check your timing belt is open the timing belt cover but I think you have to remove the valve cover din to get to it.
    Wala naman sound usually, basta nalang mapuputol, kaya nakakatakot, so usually you change it sa recommended interval to be safe
    marwen::: Pag timing belt mo ang naputol, hindi na aandar ang engine. Tutukod lahat ng valves sa piston, mabubutas at mawawalan ng compression. Timing belt breakage will not produce any sound except for that 1 hard engine knock and thats it. Palit ka ng buong cylinder head, valve seats, cam, pistons, piston rings, connecting rods, sleeves, much worse kung damage pati engine block.
    Dati meron kami ditong Timing Belt tensi-check, but fortunately it got sold to one of our customers.
    All you have to do is remove the timing belt cover to inspect the belt as Hybrid mentioned. If the belt surface is shiny and hindi mo alam yung last time na pinalitan, then you could have it replaced. Medyo mahirap palitan yan coz maraming tatanggalin.
  5. FrankDrebin Guest
    ...at kapag mahirap tanggalin ang isang piyesa....MAHAL ang labor!
    Jan 1970
    Naku nakakatakot pala pag timing belt..... punta na lang ako sa mekaniko bukas.. last question..... how much does a timing belt cost..... comparison ng original from mitsu casa at yung mga other brands lang na okey din performance....and pa suggest na rin ng magandang brand reliable at hindi masyado expensive.....
    salamat sa mga nag reply..
    marwen
    Original 4D56 timing belt 1200 for belt A, 900 for belt B. Dalawa po yan. Make sure you replace both as well as the tensioner bearings. Original yun, but dont be surprised if its made in Korea.
    Timing Belt Kit for 4D56 is VKMA 95010. Which would cost you around 4K-5K on auto supplies. The kit includes 2 tensioner units and 2 timing belts. Better have the price and parts compared before making a purchase.
    Jan 1970
    Pajerokid: pardon me for my ignorance.. he.he. ano po gamit bakit dalawa ang timing belt may A and B... for fault tolerance po ba ito... and ganun din po ba ang tensioner dalawa for redundancy....
    salamat :wink:
    marwen
    no prob ser!
    Actually, isa lang talaga timing belt ng 4d56. Eto yung "belt A" kung tawagin. The other belt turns either the balance shaft ata. I dont have my manual with me right now, but i'll get back to you once i do. Hindi for redundancy yung second belt.
    yung isang timing belt para sa oil pump. may timing din yun para sa oil sprayer, mas maliit ang size nun
    Mar 2003
    Sa service manual, ang schedule ng change ng timing belt is 100,000 kms. I changed my timing belt in my L200 pick-up (a long time ago) when I reached 80k kms. Nang ma-inspect ko yung lumang belt, ok pa siya at wala pang signs of wear and tear. IMO tatagal pa hangang ma-reach ang 100k mileage. Nabenta ko pa nga yon ng P350.00 sa may ari ng L300 passenger van. Ang may tama ay yung tensioner bearing. Medyo maingay na siya. Kaya ko naman pinaltan na ang timing belt ay nagsigurado lang ako. Mas maraming sisirain kapag bumigay ang timing belt. So, payong kapatid, Marwen, magsigurado ka na rin.:lol::lol::mrgreen:
    Jan 1970
    salamat sa mga nag reply... ;) bukas sched na for PM ride ko so kasali na rin check if pwede pa ba timing belt... and lahat ng belts para sigurado....
    According to Haynes, Balancer yung pinapatakbo ng Timing belt b.
    Jan 1970
    all,
    nag pa PM na ako check lahat ng belts..buti naman okay pa yung timing belt.. sabi nung may ari ng shop matibay pa raw yung timing belt, aabot pa daw ng 10K na takbo so by 90 to 95 K na ang mileage, advice for change na raw ako... thanks to all who contributed
    cheers,
    marwen
Help: Timing Belt Effect
