Results 1 to 5 of 5
October 20th, 2003 01:48 PM #1
Guys question... I need to replace my little fuel hoses coming from the fuel filter to the injectors of my 200D, the problem is, regular fuel hoses are too thick to fit into the tight crevice of my injectors... Although I can get the right diameter size, the hose is still too thick. I tried making "tabas" sa jacket ng hose but it doesn't work...
San nakakabili ng small hoses like those? Sa mga naka AE101 na corolla, para sya yung hose na nakakabit sa PCV.
October 21st, 2003 04:56 AM #2
Those are available in RBL along Quezon Ave. near Pantranco. Just indicate that you want the high quality hoses. My former 300SD kept destroying the cheaper hoses.
I think these hoses are cut to fit. Better make them a bit longer that what you really need because sometimes the hose end can split open while you are installing it. At least you can just cut the split part off and still use the remaining hose.
October 21st, 2003 09:00 AM #3
Otep,
Sa RBL ba may mga Silicon Hoses din? I need this kind of hose (8 inches in length and 2 inches in diameter) to the piping of the pajero. Out of stock na yung mga usual distributors nito like autoplus etc...
October 21st, 2003 11:47 AM #5
Sir woodfire,
I don't think they would carry those performance hoses. RBL is mostly a Benz repair facility.
Ford Bronco Outerbanks Sasquatch ... Php4.998M ... ...
Land Cruiser 250
