Results 1 to 10 of 15
December 9th, 2002 07:32 PM #1
Napansin ko lang last Saturday, eh. Hindi pala sumasabay when I turn the a/c on. It's the big electric fan behind the grille.
Ano kaya ang cause nito?
Is this part servicable?
Am I looking at $$$ in repairs?
Parang wala naman akong makitang problema sa wiring and all my fuses are intact.
Anyways, dadalhin ko siguro kina Glenn for a check on Wednesday.
December 9th, 2002 07:40 PM #2
hanap ka surplus! Mine got replaced a couple of months ago, everything cost me 900 inclusive of fan and labor!!!!!
Unfortunately, hindi serviceable to coz pag binuksan mo, sira ang magnet(accdg to the guy at the electrical shop).
Malamang, the fan has reached the end of its useful life. You can have my defective fan, i-try mo dalin sa auto electrical, baka sakali mabuhay pa nila :D
December 10th, 2002 12:44 AM #3
mura lang yan... sa jurassic L3 ko 650 lang ung fan... wag ka kukuha ng bnew na taiwan ung surplus na japan kunin mo... taiwan is plastic made. ung japan is bakal...
December 10th, 2002 01:30 AM #4
BNew Japan is P1,200. Taiwan P700. Yan ay sa second condenser ko. The fan behind sa grill mga P400 surplus.
BANNED BANNED BANNED
- 3,790
December 10th, 2002 07:19 AM #5Otep, would you be interested i DIY mo....check mo muna yung motor if it would still run kung nakarecta sa battery. Two wires lang madalas ang nasa motor (kung isa lang, likely e ground or negative ang body ng motor fan) and ang polarity nito ay reversible (iikot nga lang ng pakabila yung fan kung mali)...the point is kung aandar ang motor ng fan...malamang na hindi fan ang me diprensya.
Kung walang diprensya ang motor...it could be that the relay switch nito (ng fan) ay sira or the connection between the AC motor actuator and the relay of the fan ay loose or putol. Pede ring ung wire na nagpifeed ng 12v sa fan motor ay loose or putol.
Sana hindi ako nakagulo.
My 2 cents.
December 10th, 2002 11:50 PM #6
Salamat sa advice, baka i-daan ko muna kay kuya Ronald ni Glenn10 for a quick check up. Hindi naman nag-ooverheat and may lamig pa naman ang a/c, eh.
Pero kung kailangan palitan, malamang Japan surplus na ang gagamitin ko.
December 11th, 2002 12:01 AM #7
yung sa crv ko din sira yung fan. kaya pala ayaw lumamig yung aircon pag tanghaling tapat. umiikot pa naman yung fan pero walang hangin.
Signature
December 11th, 2002 11:26 AM #8
mag hi-high pressure aircon mo nyan sasabog hose mo. kailangan pagawa mo sa lalong madaling panahon. ang nangyari sa fan mo ubos na carbon. disposable naman ang mga fan na ganyan kaya kailangan palitan mo na.
December 11th, 2002 11:33 AM #9
daryl,
Sana naman hindi pa sumabog ang hose. Some guys I know have had this problem in their trucks for over a year now and intact pa naman ang a/c system.
Anyways, hindi ko naman masyado ginagamit ang a/c kasi umaga ang pasok ko and gabi na ang uwi (bakit kaya ginagabi? Hehehe).
Bad trip, ang dami pang work dito, hindi ko madala kina Glenn10 for a good check-up.
December 11th, 2002 11:44 AM #10
mag yosi na lang hehehe puff puff!!!!!! nangyari na kasi sakin yan dati bumagal pala ikot ng fan ko. pag umiinit pala ang freon lalong nag-eexpand...... ndi naman sumabog ang hose ko , kaya lang nagkaroon sya ng maliliit na leaks. kaya pala ndi makita tagas ng aircon ko noon andun lang pala sa hose. ang sakit nya non lagi nauubos freon unti unti.
dami mo namang auto eh. gamitin mo muna yung iba hehehhe o kaya yosi na lang :mrgreen:
Telegram: Contact *pump_upp - best crypto pumps on telegram Make 1000% and more within 1 day,...
2016 Mitsubishi Montero
