Page 7 of 7 FirstFirst ... 34567
Results 121 to 134 of 134
    Originally posted by trup
    Some pics
    :offtopic:
    *trup pahiram ng pic
    galing naman ng auv na to..... pwede rin pala xwind ko:bwahaha:
    body na lang ba natira dito? ano kaya makina naka install dito sa fx na to? dami ko tanong........
    Toyota 2L with 4wd tranny yata...:confused:
    the blue fx is owned by paul javier
    infos:
    2c turbo engine
    range rover chassis and tranny
    mechanical winch
    infos:
    2c turbo engine
    mechanical winch
    galing naman may ari nyan.........basta pinoy lahat pwede
    infos:
    2c turbo engine
    mechanical winch
    Yung Engine toyota pero tranny Rover?:confused:
    Correction po:
    12R Toyota gasfed engine yan
    Toyota dual transfer case with PTO winch.
    Land Rover differentials.
    1SMF batt.
    and a leaking radiator. :D
    as of the day of the rescue kse naka 2c turbo diesel engine sya, i'll ask paul to confirm, winch daw yun nung 6x6 nya
    :offtopic:
    sir ungas ba yun nasa pic
    How could Paul switch engines inbetween rescue at Maarat? We were practically hours away when you guys went down, and I went up with afrasay. :D
    Winch can be shared by many vehicles as long as mountings and parts are the same. Kaya po PTO winch yun, power only comes from the engine thru transfer case.
    naka 2c na sya before the recovery, he even showed it to us (alfred & me) pang corona daw na jdm
    Originally posted by Ungas
    Naman eh! Nang-aano ka nanaman odell! :D
    OT:
    Pero kidding aside kung gusto mo malapit sa offroading dun sa Maarat, may nakita akong bahay for sale along the way. Nasa taas ka na ng bundok, malamang pwede mo na rin lakarin papuntang table top.
    ungas::: para kayong mag ama. HAHAHAHA
    Originally posted by Kicker15
    guys again thank you very much dun sa help ninyo. kahit na galit kayo kay emboy pasensya na po. sana he learned from this experience, i know i did.
    hindi po kami galit kay eman. he was just in the wrong place at the right time.
    I'm a guy who looks for something positive in times like this. Here they are:
    1. The recovery team found out that my timing was off (delay). This could have contributed to the engine conking out during the ascent on that faithful afternoon.
    2. Water could be present in my gas tank. Change the tank cover with a sliding keyhole cover. Samurai tank has no drain plug. I guess I just have to wait until the tank is almost empty and fill it up full.
    3. Ignition coil (OEM) has a loose inside connection. Replaced it with a BOSCH unit. Better getting stuck up there than in a deserted street in Metro Manila.
    4. All of the above could have contributed to my low gas mileage.
    5. I had one broken shock and shock mount. Had it repaired at Elias place. Found out that KYBs shock are cheaper (P635) at Fernando's than in Banawe (P850).
    6. My clutch system is still fine.
    BTW, did I mention that Trup gave me his SIEMENS ME45 car lighter charger. Thanks Trup.
HELP:  Mt.  Maarat 4x4 Rescue Team Needs YOU!
