Results 1 to 18 of 18
    Jan 1970
    Guys,
    it's me again, PK, Otep, Ungas, 4D56 TDIC boys and diesel peeps HELP
    ... just curious with my intercooler, before kasi, when i switched the key to On before the tik sound and before starting the engine a humming noise that comes from the intercooler is heard. Ngayon kasi wala na.. as in before i start the engine.. hmmmmm me humming sound talaga.. just wanna know if that's okay... ?
    How to know and test if the intercooler is working.?
    How does intercooler help on the engine performance.. pwede pa explain na rin.. thanks.....
    if ever my thread na regarding my questions.. pwede pa post sa link...
    thanks ...
    do you mean the turbo? the intercooler is a passive device. it always works as long as air passes through it.
    If you wanna test the turbo, just remove the hose connecting the turbo to the intercooler. Kung may hangin na lumalabas, then its working. better yet, silipin mo kung umiikot ang turbine. be careful, baka mapuwing ka.
    addendum.
    The 'tic' sound probably comes from the glow plug relay, as long as nakakastart pa rin yung making mo, oks lang.
    suspecha ko, naka recta yung intercooler fan mo, like mine. Usually, this is temperature controlled. That's probably why may humming sound when you turn the key to the "on" position.
    Kaya nawala, baka sira na yung fan. try disassembling the Intercooler assy and check the fan's status.
    goodluck! :D
    Aug 2003
    pajerokid,
    sir, tanong ko lang if ucan refer some one who repairs turbo. mine on 3-dr paj 4D56 may tagas na oil and may whistling sound like air leaking. please help, i need to have it checked asap. please txt 0917 5361583, thanks a million....
    chull_al,
    hmmmm. you have to distinguish between a bearing leak and exhaust gas recirculation. its possible that the oil you see comes from blowby gases reintroduced into your turbo. dibe there's that liitle hose on near the air filter assy.
    the whistlins sound may come from a hole in one of the hoses.
    wala akonh kilala eh. :D
    Aug 2003
    pajerokid,
    thanks alot kilala ka pala ng nephew ko si boyboy nakasama nyo sa pinatubo trekking. saw your pix too in that trek hope makasama ko next time, if your group allows it. thanks again
    No problemo sir! Kamusta nyo na lang po ako kay Boy2! :D
    An intercooler does not have any moving parts. It is just a radiator for your incoming air. So dapat wala kang maririnig sa kanya (except for the fan hum). Yung click, malamang sa glow plug relay iyon beside the I/C.
    An intercooler works by cooling the air before it comes into the engine. Cooler air is more oxygen dense. More oxygen equals more power.
    Originally posted by marwen
    Guys,
    other peeps might be right that your intercooler fan is naka-recta. the tick sound that you've heard might have came from the glow plug relay. the humming sound afterwards might also be coming from the aircon aux fan. if your a/c was turned-on prior to ignition, the aux fan likewise will be turned-on. the aux fan will automatically be turned off if it reaches the set temperature. please check kung dito nga galing. if its not and you suspect that its the intercooler fan, it might just be a case of a stucked-up intercooler fan motor. there are certain ways to check this, you can supply 12v directly to the motor if its working. if its not, its either a time for a carbon change, or a bearing change.
    hth!
    regards,
    Jan 1970
    Originally posted by pajerokid
    addendum.
    goodluck! :D
    Thanks PK youre the man...
    binalik ko na sa shop and so far.. okay na uli... pina reassemble lang yung intercooler... siguro nga may na stuck ...
    yung sinasabi mong naka recta... sabi kasi sa akin ng owner ng shop.. pwede daw nila gawin yun pero advice nya mas madali daw masira motor ng fan..... so di ko na lang pinagalaw... okay lang daw sa temperature controlled yung fan... umiikot naman daw...
    thanks to all...
    Dec 2002
    Question: the trooper has an intercooler but i don't see an I/C fan? Do all I/C's have a fan, if so, where is it?
    Jackaroo, not all intercoolers have one. Im not really familiar with the trooper's so i cant really say.
    In the pajero, its located under the intercooler, and is visible from the left.
    Astig yung intercooler ng EVO. May water spray pa!!!
    Sir jackaroo,
    Not all intercoolers have fans. Our Trooper also doesn't have a fan.
    meron kasing hood scoop ang trooper, patrol, strada's, new pajeros kaya di na kelangan ng I/C fan. yung pajero nila OTEP, pajerokid and marwen, walang hood scoop kaya kelangan ng fan for heat transfer.
    Signature
    Boybi, ahem! May hood scoop ako Anyways, yung mga Gen2.5 may hood scoop and fan
    hehe, sori pajerokid, kalimutan ko nagpa surgery pala pajero mo
    Signature
    gen II pajero may built in na air passage sa hood. Confirm nyo mga gen II owners. may rubber sa tip ng hood na papuntang intercooler, it scoops up from the top most opening of the grille.
    Yup, 4d56 na GEN II sa grille kumukuha ng hangin via the hood's double wall.
Help:InterCooler Turbo How to know if its working?
