Results 1 to 10 of 26
- Jun 2005
- 73
June 28th, 2005 02:16 PM #1I've read this from http://www.warfs.org/content/view/20/51/
A site for Daihatsu
A good budget way to get some more height in the rear is to fit a set of Longer Shackles - these can either be custom made fairly cheaply or a set from a similar 4wd may fit if you look hard enough ( Jeep YJ front shackles can fit I believe - make sure you get some measurements first though ! ) Do not go more than a 100mm ( 4 inch ) longer shackle - better still keep it to about 50mm ( 2 inches ) longer to be safe. A 50mm longer shackle will give you 25mm ( 1 inch ) lift. ( ie: total lift is half of the extra shackle length ). You will also need longer shocks to suit.
Thanks.
- Jun 2004
- 476
June 28th, 2005 04:03 PM #2If your rig has leaf springs then it will be applicable. Keep in mind that you may have to get longer dampers to compensate for the lift.
- Jun 2005
- 73
June 28th, 2005 10:24 PM #3nabasa ko kasi sa website na ito: http://www.barneymc.com/toy_root/tec...n/shackles.htm
may isa na nagsasabi na:
I still feel that if you lift a truck with a 2" longer shackle, the truck
isn't lifted a full two inches. It may not be exactly 1/2 that, but it
will only be about 1-1.3" higher.FWIW, I used a 3"(longer than stock) shackle on my 88 4Runner and my
lift was exactly 2".The others argument of shackle length = 1/2 lift height gained does not
truly equate on Toyota springs because the axle is not in the middle of
springs but the length=1/2 lift gained is a good rule of thumb in most
cases.
Tsikot Member Rank 4
- Oct 2004
- 2,315
June 28th, 2005 10:44 PM #4nag shackles lift na din ako on my frontier. Pwede po Engr yun sa adventure. My cousin tried it na. Mura lang po ang shackle lift.
- Jun 2005
- 73
June 29th, 2005 01:23 AM #5Originally Posted by quiksie
- Jun 2005
- 73
- Jun 2004
- 476
- Oct 2004
- 2,315
July 1st, 2005 05:48 PM #8Engr mga 1.5 lang siguro ang tinaas or an inch. Hindi ko nasukat yun dati pero noticable yun lift kasi compared sa height ko dati mas tumaas. Tapos torsion crank nalang sa harapan.
My cousins adventure lift is 1 inch sa likod putol springs sa harap ng 1.25" parang nakasubsob ang adventure niya.
- Jun 2005
- 73
July 2nd, 2005 05:43 PM #9salamat po sa mga replies niyo.
may additional questions lang ako:
kung mag li lift ako ng 1.5" or 2";
kailangan bang i-maintain ko yung dating angle of the of the pinion flange or hayaan ko na lang?
yung "Load Sensing Proportioning Valve" (LSPV) kailangan ko din ba itaas?
July 2nd, 2005 09:07 PM #10
my delica was lifted 2 inches more..in the rear, i used that kind of method...i change the shackle for a longer one..but, te shackle kinda protrudes in the rear(beacuse the shackle i use can be +0, +2, and +4 inches
so far, for my 2 inch up, i didint changed my shocks.
Daming issue ng SU7:grin:
Xiaomi E-Car
