Page 2 of 2 FirstFirst 12
Results 21 to 37 of 37
    odell, pasakay naman sa patrol mo. teka, 4x2 ba ung patrol mo?
    4x4 papi
    The power system will usually compensate. But the mechanical drag on the engine is still there. The engine exerts more effort in moving the vehicle.
    Quote Originally Posted by OTEP
    kung naka 4x2 lang, e di wala ng mechanical drag from the engine. yung mga 4x2 na patrol, always locked ang front hubs.
    Signature
    Feb 2005
    Eh papano po yung mga 4WD na nakikita ko na sinasabi po ay "Auto Fee Hub"? Does that mean po ba na kapag mag-disengange, dehins na kailangan umatras?
  6. #6
    Quote Originally Posted by nicolodeon
    kelegan talagang umatras....
    noon and sometimes on stoplight i played with the 4wd lever(2h->4h->4l->4h->2h)
    one time i forgot while playing,i accidentally put on 4h when the traffic moved a bit..binalik ko agad sa 2h..kala ko ok lang kasi di umilaw ung "wheel lock"warning light.
    while cruising on commonwealth ave at 60 kph i heard rattles under me(kasi diba tires ng delica nasa ilalim lang) then i stooped in the middle(buti wala akong kasunod)when i looked at my guage,the warning light is on!(naku patay sira na hubs ko..patay ko kay dadi!)
    i back a bit then forwarded,i heard my hubs disengage then everything fine..
    buti di nasira..
    kaya i alwayz back-up na....delica pala will still lock the front hubs even at 2h when not backed up..
    although inspected na ok hubs ko,di na normal ung locking nya,nawawala ung warning light below 20 kph the on again at 35khp++
    based on my experience...auto hub talagang dapat atras muna bago abante ulit!
    pag manual,di dapat ikot mo ung knob sa hub?
    Feb 2005
    "Auto Free Hub" . . .Dehins na kelangan umatras. . . sa Terrano yun ha, i don't know sa Delica.
    Feb 2005
    Sa Delica ko po, ganun nakalagay. Kaya lang, takot akong subukan. :puyat:
    Jan 2003
    kahit na auto lock/unlock hubs pa...dapat mag back up ng 1-2 cars away para at least sure...minsan tinatamad akong mag back up..pero pag naiisip ko kung magkano ang gagastusin pag nasira, hehe, back up nako! :D
    Feb 2005
    Oo nga, kapag ginamit ko na yung 4WD feature, back-up na lang ako para sigurado. Kung masira, malaki gastos sigurado. 'Patayin ako asawa ko!
    Death by for 4WD
    The 4wd on the Delica is use mostly on snow in Japan. I won't take it on the trails that we usually go.
    Sa auto hub kailangan umatras. Sa manual hubs (old school) or axle disconnect system (e.g. Pajero), hindi na.
    mga chongs ako ang living example na dapat umatras...
    sa kasamahan palad sa taas pa ako ng high peak zambales nasiraan, buti na lang nandyan si DC.org prexy para hatakin ako
    2500 ang isang auto hub...surplus pa yun.
    Feb 2005
    2500? Medyo may kamahalan din pala. Atras na lang kaysa 2500.
    Oct 2003
    Well said Tsikot 4x4 gurus!!!
    Nicolodeon: You might want to check also the www.4x4ph.comwebsite. Some of the gurus here are moderators of that site.
    Feb 2005
    Thanks for the info! Much appreciated. Hail, Tsikot 4x4 gurus!
To experienced 4x4 enthusiasts, help naman.
