Page 1 of 2 12 LastLast
Results 1 to 20 of 35
    Hi diesel ppl,
    Just a registered NuB po. I have a '92 hyundai grace van. Napansin ko kasi na medyo mahina sya humatak paakyat (bundok kse sa 'min). Can't help to compare other vans na nasasakyan ko papunta sa 'min.
    From primera to segunda maganda yung hatak nla.
    Any enlightenment is very much appreciated.
    Thanks.
    Hi Lamont,
    Welcome to the forum!
    The easiest solution is to check your air filter. Clean it, or better yet, replace it.
    It would be helpful if you can post the mileage of your ride.
    Also, you might need to calibrate your ride already. Sasagot ang mga diesel gurus for sure about that...
    Quote Originally Posted by lamont
    Hi diesel ppl,
    Thanks.
    add ko lang...try to check din the spark plugs baga madumi na yung contacts resulting in less fuel burn.
    Hi Dieseler,
    Thanks for the welcome and the reply. Mileage is around 37k na bought it just last year.
    gas ba makina ng grace?
    huh? diesel or gas?
    may gas kasi na grace may diesel din
  7. FrankDrebin Guest
    Galing ba sa Auction yung van mo?
    mga sirs,
    me grace is diesel po, d4bx sya, i think parehas to sa 4d56 ng mitsu...?
    bli ko sa may makati, not from auction. :-)
    Based from my experience on Hyudai engines, nagbabara agad yung filter sa loob ng injection pump, minsan 2 or yung iba 1 lang. :D
    Ano year model ng Grace mo? D4BX engine? Alam ko sa mga bagong Hyundai Starex nakakabit eto. The old engines of Hyundai is D4BB. ( I might be wrong, might have to check on this ) :P
    Hi Ungas,
    are u referring to fuel filter o iba pa yun? yun ba yung parang baso?
    tnx.
    lamont::: Nope it's not the fuel filter. Injection Pumps are small engine-like part sa tabi ng makina, right after the diesel fuel exits the fuel filter. :D
    This is the last part wherein your diesel will be pump before it reaches your engine.
    i see
    iba pa pla yun, advise kse nung nakausap kong mechanic, palitan ko daw muna yung fuel filter tapos palinis yung air filter, tapos i-timing daw... i plan to have this nxt month pra me budget :lol:
    lamont::: It is common that their first suspect is air and fuel filters be replaced then if the problem persists, your injection pump would have to be checked. I don't think adjusting the timing would be the next one, IMO. :D
    if problem persists, calibrate na b...or palinis lng ng inj pump, any ideas magkano..
    Try going thru the cheapest solutions muna... yung change air filter and fuel filter... pag di na solve yan, tama si Ungas, you need to have your injection pump checked.
    May mga expert tayo dito ng Diesel Calibrators, sina DOC DIESEL at si HANSON.
    if all filters have been replaced and problem persists then you should try to make a visit to your nearest, trusted, trained, well-equipped calibration center.
    hanson
    Korek din si hanson, thanks for the back up Dieseler :D
    salamat sa help mga sirs, if problem persists then I really should try visit sir hanson's center....
    sir hanson, could you give a rough estimate ng calibration costs?..... meron bang malaki-laking discount :D:D:D...
    Wala ba iyang mini-strainer sa fuel line kagaya ng 4D56. Baka iyon ang barado. I remember how much effect it had on Dieseler's ride according to his stories dati.
    May detailed instructions si Kupaloids on cleaning it. Nasa "Maintenance...." Thread somewhere dito sa diesel forum.
    in terms of calibration, sa isuzu engine (crosswind, fuego) pinapacalibrate din ba ito? di ba direct injection ang engine ng isuzu?
hirap humatak
