Results 1 to 12 of 12
    Oct 2005
    Hey, i've got a isuzu bighorn 93 model.. anyone here knows how to determine if its differential has LSD? Physical characteristics? i plan to change the differential gear oil but can't seem to find out which one to get... thanks..
    Put wheel chocks/block on front wheels
    Jack both rear wheels up
    Release parking brake
    Spin one wheel
    Opposite wheel spins in same direction - LSD
    Opposite wheel spins in opposite direction o OPEN Diff
    Oct 2005
    thanks bro! didn't expect a reply this early.. hehhee thanks alot!! i'll do that later wen i wake up...
  4. #4
    diba iba ung gear oil for LSD diff than a reg diff?
    if so saan kaya makakabili ng gear oil for LSD diff?
    check mo yung plate sa firewall sa engine bay, the plate with the VIN number, engine number, and chassis number. sa lower part you'll see options with different codes, pag may G80 it means LSD equipped yun
    Quote Originally Posted by alwayz_yummy
    You can buy LSD gear oil or you can buy LSD additive to add to your standard gear oil. Sa SM Ace meron dati nitong LSD additive.
    Aug 2004
    what's the difference (pros and cons) between the LSD and the Open Diff? thanks.
    Open Diff
    -Transfers power to the wheel with the least traction (imagine L300 backing up a steep driveway in the rain)
    -Simple and cheap
    LSD
    -Still sends some power to wheel on opposite side should one lose traction (I've tried this with a Starex LSD, it works)
    -Not as cheap or as simple to produce
    -Can become noisy over time
    -Excessive use in low traction situations can also 'wear out' the LSD in some vehicles (magiging parang open diff na lang siya)
  9. #9
    basta GL-5 yung gear oil ok s bighorn yun.
    madali lang yan, tignan mo sa identification plate kung may G80 na code, kung meron may LSD yan.
    Aug 2004
    last monday nagpapalit ako ng gear oil for the front/rear diff ng swb bighorn. 5.5li shell GL5 yung ginamit. hindi ko natanong tungkol sa lsd kung meron. check ko nga mamaya yung identification plate code. if merong lsd separate ba yung lalagyan ng oil nito sa rear diff? thanks.
    With or without LSD, the fill hole is the same.
Bighorn LSD???
