Results 1 to 10 of 16
May 27th, 2006 11:11 AM #1
Hi Guys!
I'm looking for another compact SUV that is capable of towing a jetski riding on an aluminum trailer. I have in mind the new Gen3 RAV4 4x2 but I'm still open to other options. What can you guys recommend?
Thanks!
May 27th, 2006 03:24 PM #3
You need a small suv with a big engine..get the FORD Escape 3.0 V6..
Duratec 30 - 3.0L V6
200 hp * 6,000 rpm
193 lb.-ft *4,850 rpm
GCWR: 7,240 Lbs.
Max. Trailer Weight: 3,500 Lbs. with Class II Trailer Towing Package
May 27th, 2006 03:24 PM #4
Then you have to get these..
Trailer Hitch Drawbar, Ball Mount Class II
$31.44
Designed for 1 1/4” (3 cm) trailer hitch receivers, this drawbar can be used in the raised position to match the trailer coupler height. Features a solid steel shank, heavy steel ball platform and a durable zinc-coated finish.
Trailer Hitch Ball, 1-7/8", 2000 lbs.
$15.07
Available in 1 7/8” (4.8 cm) or 2” (5 cm) diameters, hitch balls feature forged, one-piece construction for maximum strength and a chrome finish for corrosion resistance. Designed with wrench flats to aid installation and removal. Available for vehicles equipped with a trailer hitch.
May 27th, 2006 03:32 PM #5
Or get the Suzuki Gran Vitara XL-7..
also meets all your requirements.
2.7-liter, 6-cylinder, 24-valve DOHC engine
Horsepower: 185 hp * 6,000 RPM
Torque: 184 lb-ft. * 4,000 RPM
but.. Towing capacity is only upto 3000 lbs.
still.. you got a more robust suspension, a full ladder chasis - better for towing plus you get a 3rd row-seat!
May 27th, 2006 03:35 PM #6
Hi Guys!
Thank you for your replies!
Larshell, I also own a 2006 GV and it's great to hear that it can tow 2 jetskis. OK pa rin ba siya sa uphill climbs even if may trailer? Medyo mabigat na kasi yung GV by itself.
Kiper, I was thinking of the Escape or Tribute V6 too but both are somewhat old models already. Sana magkaroon ng new models for both brands with the same powertrain.
BTW, is there any local source here in our country that sells towing accessories for mini SUVs?
- May 2006
- 913
May 27th, 2006 07:58 PM #7get the jeep liberty CRD. the diesel engine should answer ur towing problems.
May 28th, 2006 12:09 AM #8
Hitches should be available from your dealer. Toyota sold OEM hitch receivers for the GEN I RAV4. If not, can try off-road shops like RIDE, Armark, 199 ORH, etc.
Suzuki even made towing equipment standard in the GEN I Suzuki Vitara Plus series. But you'd have to get your own wiring as they did not include wiring for trailer lamps.
Hitches and accessories are also available online. Look for Draw-tite, Valley Springs, and other reputable brands.
May 12th, 2010 12:51 AM #10
Ill keep this thread alive.
I recently bought a v6 outlander last february with a tow hitch installed by the previous owner. Just now I noticed that the rear end of the car is lower by almost 2 inches than the front end. I think its because of the weight of the thing.
It doesnt look good for me and would like to make the rear lifted.
Can you guys help me and suggest what to do make the rear equal from the front or a little bit higher.
Thanks.
Interesting thread—really important to consider the broader impact of the National ID Law beyond...
National ID Law
