Results 1 to 7 of 7
    Jul 2003
    Nag Leak yung condenser ng A/C, kaya pinarepair(acetelyn) tapos cleaning evaporator put oil to compressure and preyun. Bakit hindi parin malamig kagaya ng dati. hindi lang napalitan yung dryer kasi sabi nila ok pa daw. Malamig din pero hindi kagaya ng dati, at saka ayaw pang mag automatic yung thermostat niya. Original pa kasi yung thermostat at saka gumagana naman dati. Ano kaya ang problema. Hindi kaya masyadong marami ang nailagay na oil don sa compressor?
    baka kulang yung nilagay na freon? ano bang car mo and year model? baka mali yung nailagay na refrigerant. newer cars use R-134a while older ones use R-12 ba or R-22?
    Signature
    Dec 2003
    r12 po ang older cars, ur thermostat could be kapoot, in my ek civic's case before it was a plastic thermostat which was clipped to the evaporator. another thing could be low refrigerant, maybe they didnt fill it to proper specs.
    Kung nag repair ng condenser coils and nag linis ng evaporator coils, nag bukas s'ya ng system. This requires thorough vacuuming before recharging with refrigerant. Baka may moisture pa ang system kaya di kasing lamig ng dati.
    Quote Originally Posted by acenie
    The thermostat will simply do its job if the system cannot remove heat effectively from inside your ride. That is, kung di nari-reach yung set temp, di nya cut off the compressor.
    Jul 2003
    Quote Originally Posted by TEAL
    Pinahanginan naman noon den after inilagay niya nila ng refregerant with oil daw. my car is L300VV, ang inilagay na na freon daw is 40 yun at saka oil nga half ng 8oz. yun ang nakita ko
    Vacuuming makes use of a vacuum pump which removes moisture from inside the tubes and is done before recharging with freon. Mas matagal ang vacuuming, the better.
A/C problem
