diba yung bumpstops yung rubber thing na nasa may arm? diba pag nalift mas malayo ang bumpstops dapat? how come (after reading the past threads on lifting) kelangan pang putulan? baka naman mali ang nirerefer ko na bumpstop... :D
there are two bumpstops the compression and the extension, ang pinuputol ay ang pang extension.
my ride is a nissan safari and the bumpstop on the right side of my car is worn already. i noticed that a chunk of the rubber was missing probably 1 1/2 inch. is it bad if left ignored?
meron bang available dito na low profile bump stop a.k.a. as snubbers?
yes there are snubbers available from energy suspension.
bilog-sa safari front? orig coils? if orig coils normal yan because the orig coils sag in time and cannot hold the weight of the car so palagi nag rerest sa bump stop ang spring seat.
ARB, yes it still have the orig coils but i have replaced the shocks though. Dapat ba sabay sila papalitan? i mean the shock and the coil?
it depends if malapit na ang bump stop and you can always feel na it hits the bump stop then time to change to new springs, common sa mga safari napinapalitan namin ng OME coils ay sira ang bump stop sa front.
energy suspension products are available at Jojo 4wheel parts supply, supplier ng Rancho products.
I just took a saw and hacked my OEM bumpstop at no cost. Ganun din si kimpOy. :D
Go under truck.
Look at the upper bumpstop. The one that will catch the control arms from dropping to low (e.g. when you jack up the truck).
Hack those bumpstops to half or 1/4 of their height.
Project done.![]()
eto ba iyon?
Yep that's it! :D
Yep, both of them must be hacked to allow the upper control arm to drop more.
rig: lifted converted safari
suspension: old man emu
paminsan minsan i hear a sound na tagadag for 5 - 10 secs while cruising on the smooth pavement. First I thought nagulungan ko lang ang mga small bato pero when I checked the road ala naman smooth pavement iyon.
ano kaya yon?
