Results 1 to 20 of 20
    I have these as OEM tires of my ride. How good are they both on-road and off-road? :D
    They are primarily designed for use on road. As such they are not fitted with much sidewall protection or the aggressive tread pattern of their A/T and M/T cousins.
    They are also a bit prone to 'bukol' especially in the sidewall areas.
    But they are quiet and refined. I don't know about on-road traction. Hanggang sakay lang ako, eh. hehehe.
    Thanks sir Otep. Ano po ba iyong gray colored belt na nakapulupot sa rear tire ng Pajero ninyo sa sig ninyo sir? Thanks.
    tow straps po yan.
    ginamit po yan nung hinila yung jimny while we were going up high peak
    Sir tebs,
    Bakit naman po hinila ang Jimny? Mahina po ba ito sa off-road? :?
    not a bit! sa totoo nga, bilib kaming lahat dun sa jimny na yun e.
    isipin mo ha, naka h/t tires, all stock. nakaabot sa taas ng bundok na puno ng bato ang daan. click mo yung link sa signature ko, dami pic dun(pbase ko)
    umiwas sya sa mga taong nakatayo sa trail, di sinasadyang mashoot sa gilid na malalim ang butas. kaya kinailangang hilain.
    after that incident, the jimny just hopped up to the peak :mrgreen:
    Mar 2003
    sa anong car yan nakakabit? dueler din stock sa cr-v... i find it a bit noisy. pero tolerable naman.
    Strada po sir cardsVR.
    Mar 2003
    OEM tires din ito ng strada ko. Replaced them when I reached 10,000 kms. for safety reasons. Madaming bad reviews including madali daw sumabog, as what sir otep had mentioned, prone sa bukol sa sidewall, it wears fast, etc. From my experience with these tires, ride comfort was mediocre(matalbog at rough ang ride), traction was bad, maingay ito considering dapat quiet siya dahil highway tire siya(mas tahimik pa ang pinalit ko na Yokohama Geolandar a/t +2), and very noticeable ang thread wear after 10k kms.
    Read the reviews about these tires at tirerack.com.
    Mar 2003
    stock tire din ng pajero. 36th kmd tinakbo. so far wala pang bukol. thread wear sa tingin ko aabot pa ng 50 to 60 th. pantay naman ang kain niya. nagexperiment din ako sa tire pressures pag 28psi umiiyak sa tight turns, pero nung 35 psi na makapit na siya. in theory akala ko nga mas may grip pag low pressure. IMO
    yan din ang oem ng trooper. di naman matagtag, ewan ko lang baka malambot na talaga suspension ng trooper. sa thread wear di ko pa masabi, nakaka 8T kms palang.
    Signature
    korek ka mangyan!
    yan din ang stock tires ko sa strada ko
    it's good for 1.5 to 2 years lang
    nag bukol na yung sa akin, and nag tear up na rin
    imho habang may trade value pa iyan
    palitan mo na,
    i switch tires from brdgestone HT to
    yokohama geolandar A/T+ 2
    now my thread is Bridgestone M/T
    Dec 2002
    How does Dunlop grandtrek AT2 compare to Bstone AT or Yoko geolandar AT+2?
    Quote Originally Posted by mangyan
    CarsVR,
    ayan ganyan na ganyan reviews sa Dueler H/T kaya magpalit ka na in the future hehe
    Mar 2003
    add ko lang mga sirs, i had our '99 pajero serviced sa casa kanina for its 30k km check-up. among d things dat i told dem to fix is d slight tire wiggle at 100km/h. dey told me na baka balancing lang. wen dey called me up, dey told me na oblong daw yung gulong, but not d mags. so wat dey did, dey just put d 2 gud tires on d front n balanced all four. pangit pala tong bridgestone na to, and 2 think, 30k km pa lang namin ito nagamit! cud u guys give d average prices of d good tires u sirs earlier recommended? mahirap na matsambahan e. tnx :D
    Quote Originally Posted by Mike2
    definitely not for OFF the road.
    pero kung lalagyan mo ng TIRE CHAINS baka pwede.
    Mar 2003
    FYI, I got the Yokohama Geolandar AT +2 at Php4350 each at Princess Tire Supply. Trade-in value po ng OEM tires which were BS Dueler H/T(10K for its mileage) ay Php1500. Ang alam ko ay mas mura ng konti ang Dunlop Grandtrek AT2.
    mas mura ang trade in value or ang brand new?
    Signature
    i think i've read, more than once, that geolandars are superior over grandtreks
    Mar 2003
    Quote Originally Posted by boybi
    Sir boybi: mas mura po ang brand new ng Dunlop AT2 ng kaunti kesa sa Geolandar AT+2
Bridgestone Dueler H/T
