Results 1 to 9 of 9
July 10th, 2003 11:41 AM #1
Baket ganun? When i check under the hood, matigas talaga even if i used my fingers to push un silinyador.
Kaya in effect, kelangan ko umapak ng umapak sa gas pedal which results to high fuel consumption.
Im riding xuv at. Iv alredy complained this to isuzu. Sabi sa akin timing lang daw. Naaayos naman nila kc after servicing my unit, ok na sya. Lambot gas pedal smooth accelation. Pero after a few days balik ulet sa dati.
*this was a previous topic but now i realized na matigas pala gas pedal ko compared to others.
- Jan 2003
- 68
July 10th, 2003 08:40 PM #7You can do the following and see if this helps. Spray WD40 on the linkage (at the throttle body) if your accelerator cable housing is accessible, spray WD40 into it as well. Let it penetrate and or better still, have someone pump the accelerator while you're applying WD40 so that the oil can penetrate deeper. Sometimes this is all you need to soften a stiff accelerator. Check the pedal linkages too and spray them. It doesnt hurt to cover all bases. If your willing, disconnect the cable from the throttle body and then spray it so that penetration is easier. Good Luck
July 11th, 2003 11:05 PM #9
i went to doc diesel's shop!
inadjust lang ulet un timing ko. took 2hrs.
maganda na ulet takbo ko! alright!!!
doc!, kung bumalik sa dating sakit un ride ko babalik ako dyan ah. =) ... ikaw na mag diagnose kung ano gagawin
