Results 1 to 8 of 8
    i noticed that the height of my pickup (fuego 4x4) is not even. i measured the distance of the rear fender to the ground. the right side is around 3/4 inch lower than the left. what can be the problem? how do i remedy this?
    doc, Front or rear yung hindi pantay?
    Di ba torsion bar yan? If i'm not mistaken, madali lang i-crank yan to lift whatever side is lower. Yung sakin ang mahirap kasi coils...
    normally mataas talaga ang driver's side kasi laging used ang side na yan. maliban na lang kung weight issue ka tulad ko he..he
    Yup, driver's side should be a little higher than the passenger side. About half to an inch taller on some vehicles.
    Try to measure the actual height with someone seating behind the steering wheel and take another measurement. And before I forget, better make sure all tires are equally inflated with correct pressure.
    i checked the tire pressure on all tires, equal naman. yung back ang mas hindi pantay. yung front parang nadamay na lang kasi nga hindi pantay yung back. i check again with somebody in the driver seat. uneven talaga by almost an inch.
    Nung nakita nyo po yung sasakyan ko dati, hindi nyo akalain na 1-1/4 inch taller ang driver side, di ba?
    how do you correct it kung rear ang di pantay?
uneven height
