Page 1 of 3 123 LastLast
Results 1 to 10 of 21
    Feb 2006
    hello guys!
    i was wondering...any chance that i could put a tachometer on my L300 diesel(4d56)? plus where can i find a store specializing in diesel tochometer instalation? they said tachometer in diesel is not a problem but the sensor for my type is the problem "big time"....
    i need your help guys.. hope you answer my questions...
    sir buy a diesel tach by auto gauge , costs u around 3.2k sa concorde , installation is easy , tatap mo lang ung sensor sa may wire sa gilid ng injector pump.
    Feb 2006
    Ok lang naman ciguro basta wala rpm yung L3. May fren ako dati naka-L3, naka-tach din, tulad nang asa pic.
    Feb 2006
    ano po ba sir yung ride nyo? same ba tyo ng ride? -tnx
    sir i drive a mitsu l200 '94 , same lang makina natin 4d56 msg mo lang ako if u have questions il be happy to help
    Feb 2006
    they said wlang daw sensor dun sa injection pump ng 4d56 ng L3 ko para dun ikabit ang tachometer?! how true is it?
    Jul 2003
    Quote Originally Posted by teamsicnarf
    wala talaga, so dapat u buy from the surplus galing ng injection ng Delica.
    il check ung sa l300 namin dto sa bahay aight :D worse comes to worst eh u can have a W terminal added to your alternator kung stock naman ung altenator mo it would be accurate.
    Feb 2006
    you mean to say there are two ways pala to have it connect the tachometer from the injection pump or alternator? alternator ko ksi stock, ano yung "W" terminal sa alternator?
    yung w terminal alam gawin un ng mga electrician lalagay lng cla ng wire between the diodes to get a pulse mga 300 - 800 php ang labor sa ganon depende sa shop if u can meet me pakita ko sayo ung ginawa sa pick up ko sir
any chance that i could put tachometer on my L3 diesel(4d56)
