Results 1 to 13 of 13
    there was a sudden downpour while i was on the road last weekend and soon enough the streets were flooded stalling cars. since i was driving a van (TD27), i was able to cross the waters and mighty proud of it (was able to bring my family home). problem now is, what do i need to check since i waded the flood no car dared cross? thanks for the inputs.
    check your radiator for debris like leaves, plastic bags, barbque sticks. check the interior /carpets in case water found it's way in. check/clean brakes
    I guess afrasay forgot to add the transmission oil. I'm sure you were playing with your clutch while the vehicle was submerged.
  4. FrankDrebin Guest
    Bearing Repack?
    Jul 2003
    i would do as follows will depends on how deep the water is.
    1. check differential housing for water and clean brake pads
    2. check transmission for water contaminants
    3. check engine oil.
    4. check starter motor.
    5. check alternator.
    Feb 2003
    I would just drive until something breaks then blame it on the water.
    this is complete.
    pls. check also your headlights.
    ROD,
    diba dapat preventive tayo? roko-roko ka talaga ha..
    hahaha! tama!
    someone told me not to engage the handbrake, pressure wash daw para matanggal mud, tama ba?
    Check your air cleaner. Mababa ang intake ng Urvan. Baka contaminated na.
    Feb 2003
    Redhorse, depende. kung ang hand brake mo is the same as the rear brakes, then you have no choice but to brake (unless mala flinstone ka). pareho lang yun kung handbrake or brake pedal gamitin mo. Very rare ang hiwalay ang handbrake. example nito Safari's. but not even all safari's have a separate hand brake system (i think).
    Feb 2003
    ROD,
    diba dapat preventive tayo? roko-roko ka talaga ha.. [/B][/QUOTE]
    HA? preventive? ano yun
    Jul 2003
    hehehe preventive ba?
    pagkatapos nung lahat ng sinabi n don't forget to put grease on the joints, etc........this will also protect the joints sa future na lulusung ka ulit sa baha.........
after flood checklist
