I think only problem #2 & #5 will be entertained by electricians. Yung problems #1 & #4 can be handled by your suking mechanic. While problem #3 sa 4WD mechanic ang gagawa. Team X Manila suggests someone named Edwin M. Better call Armark for more details.
to problem # 1 to test kung gage o sensor ang me problem pull the wire from oil sensor then contact it to the engine body if the meter deflect if ignition switch is on it means the meter is ok replace your oil switch
quindoyos, you can try wizzard along timog avenue. if you are coming from e rodriguez, make right turn at timog and drive 100 meters. it is past the dallas carwash shop.
just try to come in early since there are a lot of customers...
Sa aking pagkakaalam may ibang sasakyan na nakakabit ang tachometer sender sa transmisson. Yung iba cable type paakyat sa dial. May ibang sasakyan naman electronic na, wire lang ang papasok sa tachometer, at bronze tips ang nagpapagana sa dial.
