Results 1 to 10 of 21
March 31st, 2003 10:15 AM #1
The front wheel icons on my 4wd status indicators intermittently flash even when I'm running in 2H. Ano kaya problem nito. I'm pretty sure the 4wd is still working because there is still binding when I try to turn with the C/D locked.
I'm suspecting something is amiss with the electrics or the front axle disconnect.
Do you know any shop that can look into this? I don't think the dealer has much experience with 4wd systems.
Thanks.
March 31st, 2003 10:49 AM #2
Auto lock hubs na yan di ba?
Try backing up a couple of hundred meters to disengage it. Nasanay na lang kasi madalas mo ginagamit sa city driving on 4H.
March 31st, 2003 10:54 AM #3
Ungas,
Walang hub ito. It uses vacum yata to disengage the front axle. Anyways, basta gumagana ang 4wd so I'm no rush ipagawa. Para makahanap na din ng ok na shop.
Kanina pa ko umaandar ng paatras. The neighbors are already giving me the wierd look. hehehe.
March 31st, 2003 11:05 AM #4
Drive it backwards then forward, parang naglalaro ka lang, baka naipit lang yung vaccum nyan.
March 31st, 2003 11:15 AM #5
Ungas,
Mamya na lang ulit. hehehe. Kapag umalis na mga kapitbahay. :mrgreen: Saka ang init sa labas.
March 31st, 2003 11:48 AM #6
baka kailangan sa putikan daw mag-atras abante....ehehehe..dito lang ako..:mrgreen:
March 31st, 2003 04:17 PM #7
otep nangyari rin sakin yan sa alabang,pero after ilang minutes nawala rin,umakyat kasi ako sa gutter eh medyo mataas kaya nag 4h ako tapospagbalik ko galing ng mall nandun parin yung indicator ,kaya shift ako ng shift,eh ayaw parin kaya tinakbo ko na lang tapos nawala rin
- 400
March 31st, 2003 07:42 PM #9
Otep,
check mo yung 4wd sender unit sa transfercase. pitikin mo. disconnect then reconnect.... see if anything happens. I had the same problem when i had my ride overhauled. The batt was disconnected for more than a week.
Inengage ko lahat ng transfercase settings tapos hayun bumalik na sa normal operation.
March 31st, 2003 08:42 PM #10
otep...try this.....para mag disenggage....
habang inaabante-atras mo siya...kabigin mo right and left ung manibela....
It's looking like Shopee / Lazada / AliExpress have a long list of available parts for various...
2024 Manila International Auto Show APRIL 4-7,...
