Results 1 to 7 of 7
    Jul 2004
    Do you guys use direct injector cleaner/additive? What brand do you use? Where to buy one? How often to use one? Gas Stations I have gone too is not aware of one.
    Ako po hindi gumagamit nyan. I go to a diesel specialist para ipalinis at ipa-check yung injectors ko. Pero may nakikita ako sa Handyman na injector cleaners. ewan ko lang kung effective.
    Mar 2003
    magkano ang palinis ng injectors and ito rin ba yung diesel calibration?
    mas thorough ang cleaning kung aalisin ang injectors/noozles. iba po ang calibration sa cleaning although pag calibrate sabay linis na din.
    dun sa RF engine ko calibration at linis less than 1.5K lang gastos ko. nung nagpa-overhaul ako ng injection pump (may leak na kasi pinalitan lang ang gaskets kasi sira na) inabot ako 2.5K kasama na cleaning din at check nozzles.
    I previously use a fuel injector cleaner (Mitsu Fuel System Cleaner bago siya na-phase out) until I realize most diesel fuels already contain detergents and solvents which can clean your injectors and fuel system. (as advertised by Caltex and Shell). Ngayon di na ako gumagamit. Dadag ko na lang ang pambili ng Injector Cleaner sa fuel expenses ko since nagtaas na naman ang diesel by 35 cents just today.
    Mar 2003
    petron diesel booster 44 pesos lang. not bad na yung price. pero not sure sa result. gamit ko every full tank.
injector cleaner
