Results 1 to 20 of 45
    Feb 2010
    sir. can you explain it to me, what is twin side and twin down in carburetor?
    first, down draft carbs are mounted upright (this is the common type, found in carb cars like 1.3 corollas), they suck air downwards
    side draft carbs are mounted on the side of the engine, suck air from the side
    twin carb (or dual carb) is a carb assembly with 2 "torotot" each
    example of twin side draft carb:
    so a 4 cylinder engine with twin side carbs has 4 torotots
    Common brand name of Twin side draft carburator are Weber , Solex , Dellorto , Mikuni .
    Feb 2010
    my project is putting a downdraft to a 4K engine to have better sound and little addition in performance, someone told me that twin-side will add more performance in 4k engine (1.3L) and it will become 1600cc, but it will sacrifice more gas consumption is that true? the down draft is good for daily use is that true also? my project is having 4k engine 5 speed, down draft, 4-2-1 with muffler at the end and put it in a owner type jeep, what you think sir?
    a stock 4K already comes with a down draft carb
    what do you mean you wanna put a down draft carb on a 4K?
    it's already there
    unless you mean you wanna replace the stock carb with another downdraft carb
    twin side drafts will give you more power and increase your fuel consumption
    (kaya nasabi sa iyo magiging 1600cc)
    they suck in more air and spray more fuel
    but dual side drafts are harder to tune than stock carbs
    Feb 2010
    ah ganun ba, how about changing the stock down draft to mikuni or solex?
    4K engine have a stock down draft and it is only 2 right? how about adding 2 more to make 4 down draft? do you think it still fuel efficient?.
    toyota 4K stock carb:
    di po siya twin
    you can't add another one
    how will you mount it?
    toyota 4K stock
    [ame]http://www.youtube.com/watch?v=yB14pkhTZPg[/ame]
    toyota 4K with twin side draft carbs
    [ame="http://www.youtube.com/watch?v=mSY4USQlEnc"]YouTube- Toyota 4K Twin Dellortos *New*[/ame]
    di po siya twin
    toyota 4K stock
    [ame="http://www.youtube.com/watch?v=yB14pkhTZPg"]YouTube- Toyota 4K Engine[/ame]
    [ame]http://www.youtube.com/watch?v=mSY4USQlEnc[/ame]
    since we're talking about carbs
    this is beautiful
    6 Weber carbs
    12 torotots
    it's a Ferrari
    Feb 2010
    sir. look at this one another 2T engine but what's carburetor is that a down draft right?
    [ame="http://www.youtube.com/watch?v=PA0cmmBrGUQ"]YouTube- the hitman 2[/ame]
    yep
    that's 1 down draft carb
    other 2T engines have 2 down draft carbs (twin down)
    slight correction lang sa sinabi ko yesterday
    pag twin down or twin side, it means a 4 cylinder engine has 2 carbs, either 2 down drafts or 2 side drafts
    twin doesnt refer to the torotots
    sorry for the confusion
    Feb 2010
    yup sir. thanks ng marami yan i gain another one from you, that will be my plan installing a a bigger carburetor, one torotot at the top and exhaust system from nodalos.
    Aug 2007
    sir pasingit na din ng tanung ko?pang 4k lng ba meron?sa 3k meron din ba?pareho din ba sila ng 4k?anu maganda gawin para dagdag lakas sa makina?kasi lagi ako kumukuha ng bigas,2 to 6 sacks?
    Feb 2010
    ang alam ko parehas lng ang 3K and 4K eh... si sir. uls alam na alam yan...
    Feb 2010
    sir. anu yung nasa valve cover ng video na hitman of caloocan, like a small filter? what's that
    Pardon my ignorance mga kapatid, wala kasi akong idea how a carb system works, pero judging from the pics on this thread, wala po bang air filter ang kada trumpet na yan? Because di ba me flying saucer ang mga carb engine?
    Jun 2008
    Quote Originally Posted by mazingerZ View Post
    Pwedeng open, pwedeng may filter. Pwede rin hindi flying saucer filter, kasi pwede lagyan ng tube papuntang cone filter na malayo sa carb. Pero syempre, K&N-style flying saucer FTW.
    *4G33 question...
    Matipid naman yung sa Lancer namin. 4spd, naka headers. Nung gumagana pa yung speedo, nasukat ni lolo na nasa 10km/L yung gas mileage nya.
    Pix from the Interwebs:
    4G32 with twin-down and something like a CAI
    Stock 4G32 with flying saucer
    Eto pa flying saucer, pero aftermarket
    Okay lang po na walang element ? Di naman nakakasira ng engine?
    Jun 2008
    As much as possible, dapat may air filter. Pero ang ganda ng tunog pag open.
what are twin side and twin down?
