Results 1 to 7 of 7
September 28th, 2008 10:35 AM #1
Good day tsikoteers!
Recently had my 03 Xtrail 250x diagnosed from Nissan Westgate Alabang. The problem was whenever I start the vehicle it does not idle properly and the engine looses gas and dies. Also I have also noticed a considerable loss in power in acceleration.
Nissan Westgate told me that the problem was the idling throttle and it would cost me around 36k to change the part.
Computer Diagnostic result: IDLE AIR VOL LEARN INCOMPLETE
ENG SPEED 450RPM
If anybody can direct me to a reputable but cheaper motor shop for nissan parts I would greatly appreciate it. Thanks
Marlon
THE AUTO SPECIALIST
- Mar 2006
- 607
September 30th, 2008 03:43 AM #4
electric throttle ba yung nasa xtrail mo? kung oo, kailangang i re-learn yung IACV and throttle pedal release position. may manual re-learn yan try mo search sa web. nasubukan ko na mag re-learn ng electric throttle sa 3 nissan altima 1 lang ang successful.
kung hindi naman electric throttle yung nakakabit a xtrail mo? linisin mo yung throttle body and IAC. linisin mo na rin yung MAF sensor, yan yung kadalasan na cause ng lose power, maruming MAF sensor.
September 30th, 2008 03:43 AM #5
- Dec 2004
- 384
September 30th, 2008 02:40 PM #6Before you replace anything. Try cleaning the MAF and throttle body muna. Thats the same thing that happened to me. They told me to replace it. I told them to clean it first. My idling is back to normal now after the cleaning. No more hard starting in the morning.
Yung TOPE lang ang hindi pa nila na kuha. We tried everything but TOPE parin.
Tsikot Member Rank 5
- Nov 2003
- 3,849
October 19th, 2008 05:20 PM #7swing by. we should be able to adjust the idle using the computer assuming hindi madumi yung tb. if it is we can clean it and recalibrate the tb after.
as above, if you want to go OEM-style, get a "spare tyre lock". but i use an ordinary cheap...
