Results 1 to 10 of 26
February 26th, 2005 10:48 PM #1
hello!
i will be getting a subic LWB pajero with a 4d56 TDIC engine... its mileage is above 100k already... i plan to change the timing belt.
what are the parts to be replaced? how much would they cost?? any other things you suggest i should replace or have checked while doing the job???
also, do you have any recommended mechanic in manila area... near sta mesa or tondo??
TIA
February 26th, 2005 11:02 PM #2
sir,ganito ang real pic...4d56 owner ako..jdm delica..
pag palit ka timing belt,pwede sama mo na ito (for labor fee sake-->1 time baklasan)
timing belt,waterpump,mga bearings and oil seals..sama mo na ding ipacalibrate ang injector pump mo..mga fanbelts,clutchfans.
sorry di kita marerecomendahan ng shop,pero i suggest ung "home service" mechanic for this type...malamang matagal yan...just be ready a hefty amount..
pagkatanggal,hababg naghahanap ka ng parts,uwi ang mechaniko,sure ka sa bahay sasakyan mo...then patawag mo nalang ulit pag may parts na...
kadalasan masmura ang "home service" kasi ung mechaniko lang babayaran mo..
- Dec 2002
- 2,335
February 27th, 2005 12:48 AM #3for the timing belt & tensioner i think hindi lalampas yan ng 2K for the parts. water pump may GMB na yan most probably which in my experience is a good replacement brand ( i would guess is around 1-1.5K. ).
February 27th, 2005 09:01 AM #4
thanks for the input guys!
re; the waterpump? do you guys think i should replace it na asap?? in the odometer its alread 100,000++ kms.... wala naman ako nakikitang problem pa with the pump yet.. engine runs cool pa naman..
gary, ok yung mga estimate mo ng prices a! sang shop ko kaya yan makikita? any recommended?? pati na din sa mechanic, me alam ka??
TIA
February 27th, 2005 11:49 PM #5
Yes, get a new pump now para isang baklasan na lang. Malaki matitipid mo sa labor. GMB is good enough.
Just make sure you use 50/50 mix ng coolant and distilled water (the stuff you drink). The coolant acts as a lubricant and anti-corrosive while distilled water will not form scales or have any solid particles in it.
- Dec 2002
- 2,335
February 27th, 2005 11:56 PM #6had my timing belt changed sa friend ko sa Bonifacio Motors sa EDSA. Kung sa parts mas alam nila otep, PK yan coz mas madami silang experience at suking tindahan. if you have extra cash isama mo na yung water pump.
February 28th, 2005 09:07 AM #7
ok! isasabay ko na nga yung pump para sigurado....
thanks for the inputs!
one question though... ok lang ba ang replacement timing belt???
paging Otep and Pajerokid;
sang shop and reccommended ninyo to buy these parts???
TIA
February 28th, 2005 12:02 PM #8
suggest ko lang get the orig parts for timing belt, critical part kasi yan (along with the brake pads). To add din i guess matic yan kung subic so palitan mo na rin yung ATF fluid para swak na swak sa long drives
February 28th, 2005 06:44 PM #9
Sa Eldorado ako kumukuha ng OEM parts para sure ball na orig.
March 1st, 2005 06:59 PM #10
yes please replace the water pump na rin. kasi i also have a subic SUV and after 6 months of using it bumigay na yung water pump ko. sa EDSA pa!!! i should have had it replaced when i got the vehicle.
VinFast VF 3
