Page 1 of 2 12 LastLast
Results 1 to 20 of 26
    Apr 2004
    hello!
    i will be getting a subic LWB pajero with a 4d56 TDIC engine... its mileage is above 100k already... i plan to change the timing belt.
    what are the parts to be replaced? how much would they cost?? any other things you suggest i should replace or have checked while doing the job???
    also, do you have any recommended mechanic in manila area... near sta mesa or tondo??
    TIA
  2. #2
    sir,ganito ang real pic...4d56 owner ako..jdm delica..
    pag palit ka timing belt,pwede sama mo na ito (for labor fee sake-->1 time baklasan)
    timing belt,waterpump,mga bearings and oil seals..sama mo na ding ipacalibrate ang injector pump mo..mga fanbelts,clutchfans.
    sorry di kita marerecomendahan ng shop,pero i suggest ung "home service" mechanic for this type...malamang matagal yan...just be ready a hefty amount..
    pagkatanggal,hababg naghahanap ka ng parts,uwi ang mechaniko,sure ka sa bahay sasakyan mo...then patawag mo nalang ulit pag may parts na...
    kadalasan masmura ang "home service" kasi ung mechaniko lang babayaran mo..
  3. #3
    for the timing belt & tensioner i think hindi lalampas yan ng 2K for the parts. water pump may GMB na yan most probably which in my experience is a good replacement brand ( i would guess is around 1-1.5K. ).
    Apr 2004
    thanks for the input guys!
    re; the waterpump? do you guys think i should replace it na asap?? in the odometer its alread 100,000++ kms.... wala naman ako nakikitang problem pa with the pump yet.. engine runs cool pa naman..
    gary, ok yung mga estimate mo ng prices a! sang shop ko kaya yan makikita? any recommended?? pati na din sa mechanic, me alam ka??
    TIA
    Yes, get a new pump now para isang baklasan na lang. Malaki matitipid mo sa labor. GMB is good enough.
    Just make sure you use 50/50 mix ng coolant and distilled water (the stuff you drink). The coolant acts as a lubricant and anti-corrosive while distilled water will not form scales or have any solid particles in it.
  6. #6
    had my timing belt changed sa friend ko sa Bonifacio Motors sa EDSA. Kung sa parts mas alam nila otep, PK yan coz mas madami silang experience at suking tindahan. if you have extra cash isama mo na yung water pump.
    Apr 2004
    ok! isasabay ko na nga yung pump para sigurado.... thanks for the inputs!
    one question though... ok lang ba ang replacement timing belt???
    paging Otep and Pajerokid;
    sang shop and reccommended ninyo to buy these parts???
    TIA
    Quote Originally Posted by v22
    TIA
    Hi V22,
    Judging by your handle, it looks like you drive a V22
    Okay na diyan sa Motorix, kaya lang, the way they charge labor is the same as in the casas. Meaning, 'isang hawak, isang singil'. But of course cheaper pa rin yung labor compared to casas and there are parts all around. Haggling prowess is an advantage of course hehe.
    Sa Eldorado cubao naman, there's like a squad of mercenary mechanics who offer very cheap labor. Very good for minor repair like changing stripped wheel bolts. Parts are generally cheaper than motorix, not by much, but if youre gonna get a lot of stuff, it may well be worth the look.
    On replacement belts, hmmm.... i'd pass on these since the originals now only cost slightly more (vs costing twice) than replacements. Unless you can verify the OEM manufacturer and get the specific belt for the Paj.
    Enjoy your ride dude!
    BTW, replace both belts.
    Jul 2005
    Quote Originally Posted by pajerokid
    Hi V22,
    to pajeor kid/otep,
    sir gud day po!
    im here in zamboanga city, last year i bought a pajero from subic, the converted one, sabi its 98 model, pero tiningnan ko ung seat belt it was 92, whats d real model po? do you na kelangan ko na po syang palitan ng timing belt? present mileage is 103k nang binili ko sya it was 99k, dapad na po ba syang palitan?
    Jun 2005
    If you want to have an idea on how the 4D56 TDIC's timing belt is replaced, you can download the 4D56 engine workshop manual '91-'93 here : http://tsikot.yehey.com/forums/showt...ht=4D56+Manual
    compliments of garyq
    On pages 11A-3-1 up to 11A-3-9 you'll find the diagrams and the fully illustrated step-by-step procedure on how this is done. You'll also see where the other parts fit.
    Hope this helps.
    Oct 2004
    suggest ko lang get the orig parts for timing belt, critical part kasi yan (along with the brake pads). To add din i guess matic yan kung subic so palitan mo na rin yung ATF fluid para swak na swak sa long drives
    Sa Eldorado ako kumukuha ng OEM parts para sure ball na orig.
    Jun 2004
    yes please replace the water pump na rin. kasi i also have a subic SUV and after 6 months of using it bumigay na yung water pump ko. sa EDSA pa!!! i should have had it replaced when i got the vehicle.
    Apr 2004
    ok... i'l get original timing belts and really replace the waterpump!
    tnx for the ATF suggestion too!
    Otep; san ang el dorado??? got any contact nos??
    also... yung shop na pinapagawan ko sinisingil ako ng 1.7k to do the job.. reasonable ba??
    TIA
    El Dorado. Kahit sa top floor ng Megamall meron niyan. But I usually get from Paco. The one near Quirino Highway.
    I'm not sure on the labor costs. Hindi pa ko nagpapalit.
    Apr 2004
    hmmm.. medyo malayo pala... how about in banawe? ok ba sa mit-parts? motorix? bestcolt?
    TIA
    Apr 2004
    had the job done! all of the parts i bought in motorix... they seem to be the cheapest of all...
    tnx!
    may el dorado din sa aurora ave cor. 20th ave cubao
  19. #19
    V22: sino gumawa bro and how much cost ng labor?
    Apr 2004
    pinagawa ko sa MSF motor works, costed me 1.7k.. oks lang madami naman pakisuyo e tsaka tiwala na din ako sa may-ari kahit maiwan pa yung sasakyan...
    motorix charges 1.5k daw...
4d56 tdic timing belt questions
