Results 1 to 14 of 14
    Guys, ano pa ba ang mas durable na horn aside from Fiamm?
    I'm having problems kasi tuwing dadaan ako sa baha at mababasa eh. Right now, the macho sound of fiamm in my pickup is gone..naging parang beep beep ni road runner..hehe
    Bugahan mo ng compressed air para matuyo at bumalik sa dati.
    I'm using Hella pero same look and sound as FIAMM.
    baklasin at linisin...
    Madali bang baklasin un? May puputulin pa bang wire o naka clip lang? Hehe, cge subukan ko sa gasolinahan. Salamat otep and rod!!
    perhaps it would ne netter kung ilipat mo ng pwesto.
    merong waterproof Bosch Silver Tones.
    Rediesel,
    un nga ang hinahanap ko, ung ok sa baha. How much po yon?
    2400 sa Banawe (tawaran mo lang at canvass ka)
    tiyak maliligayahan ka sa tunog, mapapa busina ka madalas.
    baka naman natanggal lang sa terminal yung isang horn.....
    i got the same problem dati akala ko cra pero nung pa check ko...tanggal lang sa terminal...
    djerms..dalhin mo kay ronald sa shop...we revived several fiamms and hellas (like that of otep's) na...
    and pls bring the papers na.
    thanks.
    i've only used two models of fiamm so far ... the older model (single terminal) have tiny 7mm bolts and can be opened for service/cleaning but the newer model (dual terminal) is sealed and have no idea how to open without damaging it
    i discovered from tinkering the older model (kasi nabaha din) that these horns, if ever water got inside, only needed to be dried out and they'll work again, it is not necessary to open them ... i think a hair dryer or heat gun would help ... but repeated flooding will eventually create rust for permanent damage, in which case the older model have the advantage of lasting longer because it gives you the opportunity to clean the metal and apply some rust protection
    the sealed type could be open by chieseling, and could be re-sealed by blind rivets, itapat mo sa dating butas.
    i guess you are referring to a different model, one that uses rivets ... the sealed type that i got don't have rivets that can be chiseled, hence no holes for new rivets ... mukhang press-fit ang pagkaseal nito
    eto yung sinasabi kong sealed type ... walang rivets
    sealed nga, palit lang ang solusyon dyan
Sirang Fiamm
