Results 21 to 30 of 30
September 25th, 2007 11:14 PM #21
September 25th, 2007 11:52 PM #23
My brother was able to buy daw sa True Value and Concorde. P250+. Orange ang liquid nito that you can see through the packaging.
By the way, I also manually remove the dirt and watermarks off my glass by using a cocktail of cheap rubbing compound (RM brand in a can that is white in color) and some kerosene. Your glass will look like new!.
OT: O sige na nga, iho, hahaha!
September 26th, 2007 12:01 AM #24
+1 windshield washer fluid, talagang linis ang windshield... kung long distance driving at naubos na ang tubig sa reservoir use liquid dish washing soap, wag shampoo, for alternative.
- Mar 2006
- 10
September 26th, 2007 10:48 PM #25
September 27th, 2007 12:56 PM #26
pasakay na lang...how can i clean the wiper water reservoir? d ba sya katulad ng radiator na may drain plug??cheers!!
September 28th, 2007 12:13 AM #27
buti na lng nabanggit nio yung sa labas ng Ace hardware...rip off ba tlaga? balak ko ngang i-try sana eh...
- Aug 2007
- 675
September 28th, 2007 12:31 AM #28Well, Ive never actually tried it. pero Ive used the P50 refills and the >P100 refills and the difference is negligible. The one that made the difference for me was really the Bosch wipers that made the refills fit in easily.
One TV sales company used to sell the P600 wipers with "Lifetime warranty"... Kaso these so called "lifetime warranties" can often have small print indications which will invalidate your warranty by the time it is broken. That same company, for instance, no longer exists now - kaya sinong magpapalit ngayon kapag sira na?
I consider the overpriced refills rip-offs because you can purchase so many of the cheaper refills with one of their products, and the base of their wiper refill is also plastic, just like the cheaper ones. The plastic base/stiffener is usually the part which gets damaged first, necessitating a new replacement, irregardless of the rubber's condition. So kahit na sabihin nilang 100% silicon man yung rubber, or some sort of super rubber formula ang gamit, it is the plastic stiffener at the back na bibigay rin after 1 year of use.
The best refill Ive seen is the one I am currently using. The the "Clearvue" refill na walang plastic stiffener. It has grooves on its side so that you can install the metal stiffeners of your OEM wipers, kaya after installing parang OEM talaga siya! Costs only P39 sa Ace Hardware. Sa Banawe, they price was jacked up to about P100 also. I havent seen yet how long it will last. But I can't complain at P39! Even if I change that every year, Itl take me 10 years to match the cost of 1 piece of replacement OEM wiper.
September 28th, 2007 07:03 AM #29
Hmmm.
I've replaced blades, used joy on the windshield and blades, pero may mga streaks pa rin.
hirap tuloy magmaneho ngayong maulan
- Sep 2007
- 215
September 28th, 2007 07:31 PM #30joy is for dishes ... hehehehe ...
i tried wurth windshield cleaner ... 250 nga ang price ... liit nung bottle parang half ng test tube bottle ...but it really is clean ... mahal lang pero it doesn't damage wipers i think meron pa ako konti niyan to sell hehehehhe
usually try using nwb wipers mahal siya pero at least last for 2- 4 years ...
meron na rin nwb refills around 100 + din ...
meron din mga cheap brands but doesn't last that long
VinFast VF 3
