Results 11 to 20 of 30
September 25th, 2007 10:03 AM #12
Thanks for the tips!!!
Napansin ko kagabi nung pauwi nko na may clear smudge na rin yung hagod ng wiper ko. Mukhang bibili nko ng bago.
September 25th, 2007 10:08 AM #13
September 25th, 2007 10:11 AM #14
Hindi ako bilib sa Bosch wipers. Bought a pair last year, yung tropicalized for P499, pero less than 6 months later, nagsi-streak na. Medyo bumabaluktot na rin yung rubber.
I don't use the wiper that often, which is why I'm wondering kung bakit ambilis mag-degrade ng quality. Yung OEM wiper ko sa Sentra, more than 3 years na, OK pa rin ang performance.
Next December pag nagpalit ako, I'm buying another brand.
September 25th, 2007 10:30 AM #15
i don't put joy into the washer reservoir. but imo it won't be harmful naman if you put in a few drops. just don't put in the whole sachet, baka naman maging sobrang squeaky ang windshield mo. but i really wouldn't know ha...
what i do is to clean the wipers thoroughly with a sponge/towel dipped generously in dishwashing solution. i also clean the windshield itself afterwards with the same solution.
don't use shampoo, even in a pinch. the stuff will clog up your reservoir lines and might even build up residue on your windshield.
September 25th, 2007 10:33 AM #16
- Aug 2007
- 675
September 25th, 2007 10:57 AM #17[quote=Galactus;911677]
I don't use the wiper that often, which is why I'm wondering kung bakit ambilis mag-degrade ng quality. Yung OEM wiper ko sa Sentra, more than 3 years na, OK pa rin ang performance. [quote]
I think that's it eh. When we dont use rubber components a lot, they have a tendency to stiffen and break easily. Parang rubber tires, kapag nakastock ng matagal, nagiging malutong.
I used Bosch when my wipers needed replacement. I found later on though, na super dali nilang irefill! I use the P50 refills na every year thereafter. Unlike the OEM wipers, the refills work fine with Bosch kaya it was a worthy investment for me.
Pero I think yung refil na binebenta sa labas ng Ace Hardware, yung tig-P600 isa is a rip-off!
September 25th, 2007 07:43 PM #18
September 25th, 2007 10:39 PM #19
the best padin na magkaron ng wiper stand then yong frequency ng paglilinis ng wiper dapat once a week or better twice a week para di masyado dumikit yong dumi.yan lang ginagawa ko lalo sa summer, kasi ang bilis manigas ng mga mokong ng wiper.
September 25th, 2007 10:48 PM #20
Sir bbt - also check if medyo matigas na ang wiper edges mo, this is the usual indicator that you gotta replace it.
For the water tank naman, ang windsheild washer fluid from Wurth ang gamit ko and so far I've stuck with it since no nonsense cleaning talaga: No streaks, blurs or squeaky sounds.
It is available as a concentrate that will last you a long time. I used to use Joy and the like before but I noticed na parang mas madaling mag brittle ang rubber since its a liquid detergent.
the triumph of man over... man!, using the crudest of implements (by modern standards).
Traffic!
