Results 1 to 10 of 16
August 12th, 2005 12:11 AM #1
Does your turbo leak this? Mine does (isuzu fuego)! Anyone here having the same problem? If yes, what have you done about it?
I inquired about turbo servicing and repair kit price is just unbelievable! would appreciate any suggestions...
[IMG][/IMG]
Tsikot Member Rank 5
- Nov 2003
- 3,849
August 12th, 2005 07:14 AM #2where is the leak comming from? repair kits of turbines have outrageous prices. you might be better off buying a new unit.
if you will be overhauling the turbine be sure the shop has a high speed balanced for the impeller.
August 12th, 2005 09:20 AM #3
i used to think it came from those blowby oil that pass through the breather hose and then the intake but after putting an oil catch (which is doing its job), i still get the same problem...someone said it could be a leak in the diaphragm (where is this?)
anyways...im more inclined to leaving it alone until it dies, i guess that won't be any time soon as I've seen other isuzus do this in another forum.
August 12th, 2005 09:35 AM #4
do you practice cool down period? usually may mga konting leakage yan, unless na you always add oil na then it might be time to have it fixed.
August 12th, 2005 11:38 AM #5
yes i do practice the cool down method...is 2-3 mins enough after running at around 20-25kph inside the subd. with humps (another 3-5 mins of this).
no, i don't add oil...but i do consume about a liter for every 5k kms. just before my next oil change.
August 13th, 2005 08:21 PM #6
1 liter every 5k is big for a engine that has 5+ liters of capacity. pa check mo might be passing from the oil feed to the turbo. mileage mo? i have 140k same engine without oil consumption.
August 13th, 2005 08:55 PM #7Originally Posted by speedyfix
- Nov 2003
- 3,849
August 13th, 2005 09:49 PM #8most of the time kapag napabayaan yung turbine na leaking or malaki na yung play, there is wear of the impeller shaft and other areas. best bet would be to have it checked before reinstalling it. wala naman bayad kung di kelangan pagawa yung balancing. we have most of ours done by precision to be sure since they can check for play.
August 14th, 2005 11:49 AM #9
vw precision? sa kanila nga ako nag inquire... yup...speedyfix, masasabi nyo na ba kung ano ang sira or do you still have to bring it to them even just for checking?
sir yebo...baka pwede ikaw nalang mag service ng turbo ko???
mag kano ba ang singil mo?
August 14th, 2005 11:52 AM #10
*ARB: yung 1 liter eh that was only once or 2x after using it for highway driving...but normal city driving, no need to add...although im going towards that direction naren as the engine has done 194k kms already...
high idle RPM at engine start
