Results 1 to 10 of 10
- Dec 2004
- 41
August 30th, 2006 10:34 AM #1Help po mga tsikot pipol! Kanina umaga ko lang napansin na amoy GAS ung OIL ko noong nag check ako ng oil level.
Ano po problema at solution? TIA.
And also I recently changed my fuel pump 2 mos ago. Has this something to do with it?
Ride po is Corolla XL big body 1993.
August 30th, 2006 11:14 AM #2
ang fuel pump ng xl93 corolla e andun sa cylinder head, with the pump follower arm operated by the cam, tama ba? maybe punit na ulit yung diaphragm. check mo na lang, remove the valve cover and turn the engine (put a wrench on the crakshaft pulley and turn the engine by hand) until the cam on the fuel pump is at its lowest position. then you can activate the fuel pump follower by hand. pag may nakita ka na fuel leaking into the cylinder head then that's it, palit ka ulit ng pump. baka taiwan nabili mo?
- Dec 2004
- 41
August 30th, 2006 12:08 PM #3tnx po sir Yebo. Meron po bang visual indication na sira na ung fuel pump para lang maconfirm ko na un nga ang cause? Alam ko po mag leak ito pag sira na, tama po ba? TIA.
August 31st, 2006 02:49 AM #4
it is possible that you frequently flooded your engine, which leads to some of the fuel ends up in the crankcase mixing with the oil... which is why there is a smell of gasoline in your oil...
there is also a possibility that your engine is running too rich... (air/fuel mixture)
take note, a small amount isn't harmful, which incase will evaporate when the engine heats up... downside is that gasoline is an effective solvent and it will dillute the oil which in turns reduce lubrication to the engine... and you know what will happens to the engine...
have your engine check by an experienced mechanic... only needs tune-up... while your at it also change the oil in the engine...Last edited by chuaed; August 31st, 2006 at 02:55 AM.
- Aug 2006
- 337
August 31st, 2006 07:51 AM #6
Toyota is my choice
- Aug 2005
- 2,063
August 31st, 2006 07:53 AM #7
- Aug 2006
- 337
August 31st, 2006 11:16 AM #9
it will look like this. the lever with the spring is pushed up by the camshaft or push rod.
http://i2.ebayimg.com/04/i/06/f7/ea/0e_1_b.JPG
September 1st, 2006 07:10 AM #10
Try as much as possible na japan mabili mong pyesa lalo na pag sa makina/drivetrain, dapat kaw bumili ng pyesa lalo na pag dimo kabaybs yung mechanic.
alas! for obvious reasons, they are sometimes the last available slots...
PH Gov't looking to bring back excise tax for...
