Results 1 to 8 of 8
    Aug 2006
    mga sir, yung lite ace namin nag wiwigle pag 40-50 na ko,bkit kaya gnun??
    Jun 2006
    Quote Originally Posted by rad11 View Post
    Uneven na ang tread ng gulong mo sa unahan
    unahan lang ba sir or pwede din uneven yun back tires?
    Jun 2004
    Magpa wheel/tire balancing ka.
    Jun 2006
    Quote Originally Posted by ReccaH View Post
    Hindi masyadong factor ang gulong sa hulihan as compared sa unahan.
    Oct 2005
    Ipa-balance mo ang wheels mo, hindi lang sa harap pati sa likod.
    Jun 2006
    ilan taon na iyun lite ace mo?
    mas maganda ipacheck mo sa talyer or sa casa, its possible worn na iyun following: ball joint, idler arm/pitman arm, tie rod end, suspension bushing, struts and shock absorber...
    improper wheel alignment...
    loose wheel bearing...
    or simply low tire pressure lang...
    madaming reason for wiggles eh... it can be a simple thing as uneven or oblong tires or busted suspension parts.
    better yet if you consult your reliable suspension expert.
    if you are in makati or south area, bukas na daw ang cruven...
it wiggle when it reach 40-50km/hr
