Results 1 to 10 of 14
Tsikot Member Rank 4
- Feb 2004
- 1,704
June 22nd, 2004 10:48 AM #1guys, where can i get the antenna rod for my gen 2 pajero. naputol kasi ng previous owner (bwisit). kung pwede surplus lang, better.
thanks,
andy
- Feb 2004
- 1,704
June 22nd, 2004 02:51 PM #3yikes, for 3500, pagtiyagaan ko na ang mahinang reception ng radio ko
anyone know of a place that sells the rod only?
andy
June 22nd, 2004 06:08 PM #4
actually a generic rod will work. sa banawe marami, not sure lang where in Gensan my friend
- Feb 2004
- 1,704
June 22nd, 2004 06:14 PM #5kahit anong antena pala pwede? what kind of shop should i look at? car shop? sound shop?
andy
June 23rd, 2004 10:52 AM #6
mangyayari is, kelangan diskartehan yung antenna assembly. you have to get a rod which is more or less the same length as the stock one and take it from there.
- Feb 2004
- 1,704
June 23rd, 2004 11:32 PM #8
I bought my antenna rod at El Dorado. I forgot how much but it was a a bit expensive. I had to get it because I tried putting those Taiwan made ones but it was substantially longer than the stock length of the Pajero's antenna (It was so long that it kept hitting the low horizontal beams in SM Megamalls covered parking area.). It's relatively easy to install the antenna rod by yourself although you'll end up with very greasy hands after installing it.
June 24th, 2004 10:18 AM #9
true. the motor assembly is chockfull of grease. but Pajeros have antenna switches where you could adjust the length. have you tried using that?
- Feb 2004
- 1,704
June 24th, 2004 10:25 AM #10ikabod, pare, is the length the only issue? diba the pajero has a control for raising the antenna half height lang?
in any case, wala namang parking garage pa dito sa gen santos (di pa tapos yung sa KCC Mall) so i only have to worry about it when i go to Davao.
so what kind of shop do i go to? automotive? audio?
thanks,
andy
someones are (at last!) loudly asking, "why did they turn off the countdown timers?"
SC (temporarily) stops NCAP
