Results 1 to 13 of 13
    Jul 2003
    kailan papalitan ang Gear Oil, almost 2 yrs. na sa akin. my can is an L300. What SAE to be use.
    afaik, every 40K
    tama si sun tzu 40k kilometers.
    40k daw po advise ng casa.. but.. may nagsabi sakin ndi daw po tlga pinapalitan gearoil??? dinadagdagan lang pag bumaba level? ano po totoo?
    Dec 2003
    is this on mt transmissions o differentials? i changed my differential oil on my bimmer before sya umabot ng 50k.
    Nov 2003
    pinapalitan yan... every 40k. or else sasama shifting mo.
    Jun 2004
    Yup every 40k is recommended.
    For the specs, better to check out the manual to be sure.
    Nov 2003
    normally sae 90 can be used pero it's better to ask your dealer or look in the manual.
    May 2004
    Magkano magpalit ng ganito?
    Oct 2004
    Quote Originally Posted by 1997
    around 500 lang kasama labor
    Every 40K (either m/t or a/t)... but for added peace of mind if you always travel on flooded roads or get stuck in traffic and dusty conditions a lot (lalo na kung a/t), you can opt to change at lower intervals. We change our every 20,000km despite the manual saying 40,000km.
    Nasa manual yun. Every 40k nga yata sa L300. But some vehicles require more frequent changes (e.g. Kia Besta every 20K kms).
    Nov 2003
    maybe a bit more depending on the quality of the gear oil you use and how many liters your tranny takes.
    replace the differential oil narin at the same time.
When to change Gear Oil
