Results 1 to 6 of 6
- Jan 1970
- 396
February 20th, 2005 12:13 PM #1at 75T kms, i replaced the original upper control arms with replacement parts. and now at 85T kms, the bushings and ball joint for the replacement parts are already shot! normal daily driving lang naman ako, from las pinas to makati, maganda naman ang roads, always alone or 2 persons in the car, so wala talagang extreme driving. pero 10T kms lang ang tinagal ng replacement upper control arms ko??? compared to the 75T kms na tinagal nung orig!! ano experience nyo dito!!
btw, car is 97 civic.
- Jul 2003
- 25
February 20th, 2005 05:47 PM #3We have the same car (97 Civic Vti a/t). I had my front arms replaced recently at around 90tkm, but it was already bad when it was around 80tkm. I had everything done all at the same time. (upper control arm, tie rod, rack end, stab link, bushing). I didn't change the orig suspension though since it was still ok. I used all replacement parts. The 555 brand was only for the tie-rod and rack end. The others are some unknown replacement brand. After having done this, the car felt like new again. I can go over potholes and bumps with a solid feeling. It has only been around 3tkm or so and it still feels solid.
I'm not sure if your case has something to do with not changing everything all at the same time. Just a theory though.
- Jan 1970
- 396
February 21st, 2005 09:35 AM #4ung control arms hindi 555. di ko marecall, pero 3 words ung name ng brand, starts with letter H, got them at alabang parts center for P1200 per piece..
February 21st, 2005 07:08 PM #5
don't get the replacement part of the upper control arms, di talaga tatagal yan. surplus parts are the next best alternative.
Tsikot Member Rank 5
- Nov 2003
- 3,848
