Results 1 to 8 of 8
- Nov 2002
- 162
November 29th, 2002 10:05 PM #1Do I have to replace them or can I just clean them? Iridiums are supposed to last longer right?
November 29th, 2002 10:19 PM #2
unless your car isn't burning correctly (A/F mixture, injectors, etc) plugs (whether iridium, platinum or what ever), plugs will last a long time without much deposits or defects... you shouldn't even need to clean them... if you find yourself cleaning plugs often, have your ignition and fuel system checked for problems... my last set of plugs lasted over 4 years, napalitan lang coz I forgot to tell the tune up guy not to replace them.
- Nov 2002
- 162
November 30th, 2002 09:37 AM #3Thanks theveed. What plugs were you using pala? I suppose d sila stock NGKs.
- Nov 2002
- 162
November 30th, 2002 09:38 AM #4may tanong pa pala ako, pano ba linisin and palitan spark plugs. I have a lancer, d ko makita saan sinasaksak yung plugs :oops:
- 82
November 30th, 2002 10:55 AM #5may tanong pa pala ako, pano ba linisin and palitan spark plugs. I have a lancer, d ko makita saan sinasaksak yung plugs
i suggest, you go to your trusted mechanic to do this for you.
- 197
December 3rd, 2002 11:37 PM #7Iridium plugs are supposed to give a more powerful spark since the tip is very small, very little resistance.
IMHO for 800 pesos per piece, its NOT worth it unless wala ka na magasutusan sa oto mo.And the iridium plugs are very prone to corrossion, not sure why.
WHen checking the plugs, look at the color of the tip. Dapat rust / orange / reddish-brown. If white, you are running lean and burning up oil. If black, you are leaking oil into the plug holes or running way too rich.
- Nov 2002
- 162
December 4th, 2002 11:58 AM #8Gusto ko kasi ulit ikabit yung iridium, sayang e. For the price, d nga sulit na 5k ang palitan.
Hmmm, I think mine are a bit black. check ko ulit later pag uwi.
So what do I need to adjust para manormalize?
Nakakakilabot yung bagong srps taking into consideration na mag-10 years na ang current model neto.
All New Toyota Hilux
