Results 1 to 10 of 10
- Aug 2003
- 9,720
July 20th, 2006 03:06 PM #1ano po usually ang ginagamit, after working under the hood? i used to use dishwashing liquid, pero pakiramdam ko di ganun kaeffective. i resort to using detergent bar, sabay kuskos sa semento :D
di safe gumamit ng gas/kerosene di ba? although parang mas effective nga siya
July 20th, 2006 03:11 PM #2
try using an all purpose cleaner, pwede din joy :D but I havent tried it. On stubborn areas use a stronger dosage.
July 20th, 2006 03:14 PM #3
Next time po, pour some gravel or dirt on the pavement, it'll absorb all the oils and grease and you can sweep it clean leaving only a little left on the ground for a good degreaser to clean up.
July 20th, 2006 03:23 PM #4
or kung marami kayong stock ng baking powder, pwede din. bilis mag absorb ng oil.
- Aug 2003
- 9,720
July 20th, 2006 09:22 PM #7
Hands ba? If so, just go buy yourself some Citrus hand cleaner, they are GREAT, just put some on your palm, rub it all across your hand and nails and all grease/dirt will be gone without the use of water (you can, if you want)... Halos lahat ng hardware stores meron neto.
Tipid pa gamitin.
Tsikot Member Rank 4
- 2,716
July 20th, 2006 11:24 PM #8meron ata nabibili na hand degreaser sa concorde ... never bought one coz i use gloves when working on dirty stuff, especially applying tire black ... the rubber gloves are cheaper ... and if you need the thinnest, tightest glove for critical work, they might just come free from your doctor, his (used) surgical gloves ... hehehe
July 21st, 2006 04:32 PM #9
Lava soap, kaya lang mukhang bihira yun dito. but it's very good in removing grease and oil from the skin.
I remember back when I was in Kuwait after the first Gulf war when the oilwells was still burning, the fire fighters don't want to go out to the oil fields and put out the fire if there are no Lava soaps
July 22nd, 2006 12:19 AM #10
Wipe out all purpose cleaner gamit ko minsan (cheap pa).
O kaya dishwashing detergent (e.g. JOY) saka Scotch Brite.
Gumagamit din ako ng kerosene pero hindi madalas.
Xiaomi E-Car
