Results 11 to 16 of 16
Tsikot Member Rank 5
- Nov 2003
- 3,848
June 27th, 2007 11:35 PM #11yeah best thing to do would be to give more details. what did you let rapide do to your car?
- Jun 2006
- 14
June 28th, 2007 07:32 AM #12torque2006; speedyfix:
1.) its a nissan sentra LEC 16V twin cam engine.
2.) problems of the car:
- poor acceleration parang hindi makahataw other words "pigil manakbo".
- plug gets wet (oil); which cause hard starting after a long run.
- engine knodge after letting go of acceleration; parang nagcho-choke ang engine.
- high gas consumption ~5-8km/L
thanks!
Tsikot Member Rank 4
- Jun 2006
- 2,605
June 28th, 2007 12:10 PM #13Spark plugs wet with oil is not a good sign. Usually means worn piston rings or other internal engine parts. Eto yung sticky about spark plugs: http://tsikot.yehey.com/forums/showthread.php?t=28969
- Jun 2006
- 14
July 1st, 2007 09:17 AM #14already solved some of the problems by cleaning the carb thanks tsikot!
eto pa isang experience ko tuwing morning 1 click lang and start-up then after road trip mga 3x na crank bago uli sya magstart? san kaya problem?
Toyota is my choice
- Aug 2005
- 2,063
July 1st, 2007 02:30 PM #15sinyalis na yan pra overhaul bro kung may langis na ang sparkplug. paki check nlang kung hinigpitan ang sparkplug. try mo pa clean ang sparkplug tapos after 3 days check mo ulit. or dalhin mo agad sa shop ipa diagnose mo.
- Nov 2003
- 3,848
Thread was made nung 2018 pa po sir.
