Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
    Nov 2003
    yeah best thing to do would be to give more details. what did you let rapide do to your car?
    Jun 2006
    torque2006; speedyfix:
    1.) its a nissan sentra LEC 16V twin cam engine.
    2.) problems of the car:
    - poor acceleration parang hindi makahataw other words "pigil manakbo".
    - plug gets wet (oil); which cause hard starting after a long run.
    - engine knodge after letting go of acceleration; parang nagcho-choke ang engine.
    - high gas consumption ~5-8km/L
    thanks!
    Jun 2006
    Quote Originally Posted by n (o) n (o) View Post
    thanks!
    Spark plugs wet with oil is not a good sign. Usually means worn piston rings or other internal engine parts. Eto yung sticky about spark plugs: http://tsikot.yehey.com/forums/showthread.php?t=28969
    Jun 2006
    already solved some of the problems by cleaning the carb thanks tsikot!
    eto pa isang experience ko tuwing morning 1 click lang and start-up then after road trip mga 3x na crank bago uli sya magstart? san kaya problem?
    Aug 2005
    sinyalis na yan pra overhaul bro kung may langis na ang sparkplug. paki check nlang kung hinigpitan ang sparkplug. try mo pa clean ang sparkplug tapos after 3 days check mo ulit. or dalhin mo agad sa shop ipa diagnose mo.
    Nov 2003
    what part of the plug is wet? the tip of the electrode or the body?
What could be the problem?
