Results 1 to 10 of 21
    Usual plugs for the GA16 engine is NGK BKR6E.
    On the MAF sensor, it's sensor right after the airbox. it's sensitive and should not be touched nor adjusted. it can be cleaned with electric contact cleaner. Try dropping by a Nissan CASA and have them do a CONSULT readout on the engine to see if everything is running up to spec... a shop like Speedyfix or Autotechnika can also do an engine scan.
    How much po kaya magpa CONSULT check sa CASA? May shops po ba ang Speddyfix at Autotechnika near Diliman?
    Salamat.
    Nov 2003
    nope, sa shaw lang kami.
    Sep 2006
    just a noob question... when you say check timing.. what does it mean thanks...
    May 2005
    Depende yan sa AT transmission ng Maufacturer. All 2nd Gen CRV AT has that problem. All of my friends who owns one are complaining, including myself. There's a lag when flooring the accelerator.
    Sep 2006
    anong mga usual cause when it comes to check the timing?
    Nov 2003
    on older cars with distributors you check the timing on a regular basis. pero kung di naman ginalaw yung distributor ok lang to not touch it.
    on newer cars with wasted spark and or coil on plug ignition systems it is the computer that controls the timing and it cannot in most cases be adjusted by the user.
    sir speedy, magkano po ba kaya ang engine scan? corolla Gli A/T po.
    Thanks!
What causes "mahina ang hatak"?
