Results 1 to 10 of 21
Threaded View
    Go with a tune-up first by changing your spark plugs (Are you using the correct plugs?) and adjusting your timing and check/change your fuel filters. if it persists, have other items like the MAF sensor checked/cleaned (make sure the mechanic is knowledgeable on this). Do you get any erratic idling? Does the car have a hard time revving to high RPMS (this is symptom of a miscalibrated or busted MAF sensor)?
    When was the last time the ATF was changed?
What causes "mahina ang hatak"?
