Results 1 to 10 of 10
- Mar 2006
- 58
September 28th, 2006 02:34 PM #1Hi, I'm going to have my car tuned and I was wondering what are the fluids that I need to replace or prolly drained and put in a new one (Hyundai 2000 Sonata GLS M/T).
So far ito ang asa list ko:
- Engine Oil
- Brake Fluid
- Powersteering fluid
- Gear fluid
- Transaxle fluid
- clutch fluid
- coolant
- ATF fluid (pang-automatic lang ata ito so I guess I don't need this)
**I've read in other thread na pareho lang yun fluid sa iba sa taas pero I'm not sure though**
September 28th, 2006 03:08 PM #2
- Engine Oil - check your manual for recommended rating and viscosity
- Brake Fluid - usually DOT 3 pero di ko alam if new cars now use DOT 4
- Powersteering fluid - ATF works but standard power steering fluid na rin
- Gear fluid - check your manual for recommended rating and viscosity
- Transaxle fluid - usually nasa CV boot yan and if it's not torn, don't worry
- clutch fluid - DOT 3 rin like brake fluid ang pagkakaalam ko
- coolant - if Hyundai makes their own coolant yon ang kunin mo. some will say Prestone works too.
Tsikot Member Rank 5
- Nov 2003
- 3,848
September 28th, 2006 04:47 PM #3the sonata is fwd right? no more transaxle fluid kung ganun..., just gear oil. yung nasa loob ng cv joint is grease.
- Mar 2006
- 58
September 29th, 2006 08:52 AM #4
- Nov 2003
- 3,848
September 29th, 2006 04:51 PM #7
wiper washer water level,i use 1 sachet sunsilk/head&shoulders as my degerear soap, bango pa!
50-50 ang coolant/water mix->recomended, upto 75%-coolant,25% water.
engine oil, 1 gal, pero usually 3.5L lang cap ng engine, ung .5 uwi mo!
gearoil, for m/t 2-3 liters yan. may sukatan yan. atf can be a replacement for powersteering fluids...
clutch and brake fluid are the same.
battery water pa! unless MF battery mo.
- Mar 2006
- 58
September 30th, 2006 02:40 PM #8Ito yun requirements according sa manual:
Transaxle fluid - API GL-4, SAE 75W/85W
Powersteering fluid - ATF Dexron 2
Any good fluids to go with the ones I stated above?
September 30th, 2006 04:23 PM #9
Basta reputable brand (kilala) and the specs of the particular fluids are exactly like you posted, you should be fine.
On the powersteering, some people put ATF, some put P/S fluid. Either way works basta malinis din siya. On some cars there are filters too, check them and replace if necessary.
You'll have a happy car after this.
- Mar 2006
- 58
October 1st, 2006 09:38 AM #10I'm leaning towards Motul products and here is their website ng available products sa atin.
http://www.motul.com.ph/main.html
Yun Autoplus ata sa may EDSA nagbebenta ng Motul products. Tanong ko lang is Dexron 3 lang meron nila and I need a Dexron 2pwede kaya iflush yun tapos lagyan ng dexron 3?
Any commnets?
Yaris Cross: ₱ 200,000 for S HEV Zenix: ₱ 150,000 for 2.0 Q HEV CVT
Yaris Cross 1.5 S HEV CVT vs BYD Sealion 6 DM-i
