Results 1 to 7 of 7
- Sep 2005
- 9
November 4th, 2006 08:57 AM #1help naman baka me same experience... my aunts' car twice na ulan malakas
lagi basa flooring (naka park lang) just below the clutch pedal..san kaya
galing?? after rain i checked windshield, ung pinagkakabitan ng mga pedals..wala naman tulo..basta sa banda left side lang..
wala din dun sa rubber drain ng flooring..whats the best thing to do, pls help
November 4th, 2006 09:49 AM #2
Usually sa windshield talaga galing iyan.
Pwede din dun sa air intake ng a/c (the grilles on the base of the windshield)
Pwede din through a hole in the fire wall (the water falls from the trailing edge of the hood and into the firewall).
Btw, ano pong sasakyan sir?
- Sep 2005
- 9
November 4th, 2006 10:51 AM #3
November 4th, 2006 12:13 PM #4
Alisin mo yung carpet and mahiga ka sa driver's footwell. Have someone hose the car from the outside.
Bring a flashlight so you can see where the water will enter.
- Sep 2005
- 9
November 4th, 2006 02:27 PM #5tanggal na talaga yung carpet and foam sir, since typhoon..kaya madali napansin na basa yung flooring..anyway sir we'll try later pagdating ng kotse..whats and wheres the firewall (sorry)?? tsaka since tanggal na yung carpet, natatanggal din ba hard rubber dun sa drivers footwell?? that is the upper part nung carpet na tinanggal??me basa kse dun, baka dun nanggagaling hirap naman makita kse nga me hard rubber..
- Sep 2006
- 82
November 5th, 2006 11:14 PM #6suggestion: bring car to casa or expext repair shop for repair. DIYng yourself the repair might prove to be costly, tsaka saki pa sa ulo.
November 5th, 2006 11:18 PM #7
The firewall is the wall that separates the cabin from the engine compartment.
Hard rubber? AFAIK, you can remove it until you see bare steel. On some models, there is a layer of insulation (like asphalt) on the floor. That is a layer you cannot remove.
The 1.5G is good enough for me tbh My current car doesnt even have a rear camera and Ive never...
All New Toyota Corolla Cross
