hi guys,
i just bought a '92 Nissan Sentra 1.5 SGX (boxtype), id like to ask you sana of some information since i dont have a manual of it:
1. what should be the idle-up when AC on/off (rpm)?
2. what's the ideal tire pressure?
3. what is the appropriate timing (degrees BTC)?
4. what could be a good engine oil for it?
5. type of spark plugs?
6. what gasoline should i fill it with (RON)?
7. whats the correct rpm to upshift the gear (2000-2500rpm)?
8. what is its ideal fuel consumption?
9. what color do you suggest that i should paint it with?
Your opinion or knowledge is highly appreciated. Thanks in advance![]()
...have the guys painting it look for rust in the fenders and at the corners... as well as in the doors. Better to patch and weld these rust problems while you're painting rather than have the paint bubble up later.
