Results 1 to 17 of 17
    Jun 2007
    mga bro, im just curious about the tune up ng car, newbie po ako d2. ask lang po kung ano usually mga ginagawa sa tune-up ng car.
    kasi po dati ave. ko po sa kilometer/Li ay 10-11 kph nag palit lang po ako ng distributor tingin ko po ay lumakas n sa gas yung oto ko. car ko po ay AE92.
    maramiing salamat po sa mga mag re-reply
    carlo_lsy
    Jun 2006
    usual tune up:
    change spark plugs if needed
    check high tension wires
    change oil
    replace fuel filter
    clean or replace air filter
    check transmission fluid, top up or replace as needed
    check belts for damage and correct tension
    check coolant level add/replace if needed
    check hoses for damage
    kung carb ang engine, spray some carb cleaner sa carb para luminis ito.
    spray some contact cleaner sa distributor para mawala yung scales sa mga contact points sa loob ng cap.
    check the engine's timing using a timing gun.
    May 2007
    Now youve got all the answer. All you have to do now is, do it yourself (save money for labor))or bring em to shop.
    every 5k kms din ba palitan ng fuel filter?
    Jun 2006
    Best to check your manual kung kelan palit ng fuel filter.
    Kung carb ang oto mo at plastic lang ang fuel filter, mura lang naman ito at madali diy. Kung tama ang memory ko every 10,000 kms ang palit.
    Kung EFI at metal na fuel filter, medyo matagal ang sched at mahal ang filter. Yung sakin every 40,000 kms daw according to CASA, wala kasi sa manual.
    May 2005
    yung ae92 nya does not have a contact point.
    wonder kung surplus yung distributor na nilagay mo. it could be that some of the parts inside are already out of specs, like the pickup coil, iginition coil and the clearance between the rotor and pick up coil.
    kung brand new ang nilagay mong distributor (brand new cost more than P20k plus), you can rule out the distributor as the culprit in your higher gas consumption.
    aside from what userfriendly enumerated, consider also replacing the condenser kung hindi pa napapalitan. this is the one screwed outside the distributor
    Jun 2007
    sir, 2nd hand nga po yung nabili kong distributor, ang sira lang daw kasi dun sa dati kong distributor ay yung igniter. since 1 module na yun kaya napalitan n lahat. pwede ko po bang ipakabit yung igniter lang dun sa luma kung distributor? para ma maximize parin yung specs. nung dti. kasi pansin ko mula nung palitan ng distrbutor prang lumakas sa gas.
    salamat po muli sa mga mag re-reply...
    carlo_lsy
    Jun 2007
    carlo_lsy
    May 2005
    yhap, pwede. dapat igniter lang ang pinapalitan mo kung yun lang ang sira.
    ano ba problem bfore, if i may ask?
    Jun 2007
    actually sir wlang symptoms eh, nangyari sakin to noong nag company outing kami sa laiya batangas, paalis n kami nun nang ayaw n nya mag start nag crank nman engine pero wlang kuryente s spark plug. sbi ng mekanko sira n daw igniter since im newbie sa oto kya ayun isang buong distributor nbili ko it cost around 4Thou. 2nd hand pa. sa san pablo laguna ko pa nbili.
    sir san po ba nkakabili ng igniter? saka po yung rotor nasira narin po eh..
    maraming salamat po sa reply nyo.
    Sep 2005
    yaiks! dapat ignition coil lang pinalitan...nasa 1k lang yun. nagoyo ka sir. :|
    May 2005
    Quote Originally Posted by carlo_lsy View Post
    sa evangelista sa makati ang marami or banawe. if youre fm laguna mas malapit sa evang dayuhin mo na lang, pwede dun mo na rin pakabit para sure na walang problem, para hindi ka na babalik
    Aug 2005
    same lng bah igniter and ignition coil?
    Jun 2007
    actually sir seperate ang ignition coil and igniter, the mechanic said that the ignition coil was ok. so far ok naman oto ko kya lang parang npansin ko nga po n lumakas s gas. almost 6km/li lang po 1.6 16valve po oto ko AE92. ok lang po ba gas consumption ko for that model?
    TIA
    carlo
    May 2005
    TIA
    carlo
    dapat mga 7.5 kms per liter on city driving, a/c on all the time. kung laguna ka, hindi naman siguro traffic dyan ano? so, dapat you get more. sa highway mga 12 to 13 kms per liter, a/c on all the time also.
    kumusta ang kulay ng spark plug, since magpalit ka ng distributor? the color will tell you a lot on how your car burns gas.
    pag maiitim yan, you are running rich or since nagpalit ka ng dizzy, baka humina ignition, since sabi mo dati hindi naman ganun kalakas sa gas. in other words the new dizzy is medyo weak and not burning gas effciently.
    Jun 2007
    sir Asus salamat po sa mga info.sta cruz laguna po ako kaya wala po traffic. sir, ok nman po burn ng sparkplug, golden brown po lahat. wla nman pong black color sa spark plug.
    TIA
    carlo
ano po ginagawa sa tune-up?
