Results 1 to 4 of 4
    Oct 2004
    do you guys happen to know the valve clearance of the 2002 crv? Im planning on having it adjusted and it doesnt say so in the manual.Thanks
    Aug 2004
    alam ko nasa manual yan pero kung wala talaga antay natin ibang gurus
    masyadong maaga naman yata apra mag pa valve adjustment for your cr-v.
    sa owners manual di nakalist yun usually sa mga helm's workshop manual meron yun specs.
    I have the specs for the Gen1 though not the Gen2.
    Try to register at Hondasuv.com and ask the guys there pero you have to specify na K20 engine mo since most of the owners there have K24
    Oct 2004
    20,000kms palang mileage ko pero sa umaga kasi medyo matagal magredondo bago tumuloy ang makina.Dati kasi one click lang start na.I had it checked sa mekaniko ko and sabi nya baka valve clearance daw, may narinig kasi siyang parang mahinang kumakatok and suspected na baka yung nga ang diprensya.Nakasulat din kasi sa maintennace schedule sa manula na every 20k check for valve clearance. Anyways thanks for the replies
valve clearance of CRV 02?
