Results 1 to 10 of 10
Toyota is my choice
- Aug 2005
- 2,063
June 23rd, 2006 11:25 PM #1what if maliit lng ang gap like 8mm mag ka hard starting bah sa umaga?
ask lng po.. friendly replies lang.. thanx!
Toyota is my choice
- Aug 2005
- 2,063
Tsikot Member Rank 5
- Nov 2003
- 3,849
June 26th, 2006 10:52 PM #3clearance won't affect starting too much but you'll notice a roughness in the engine if you set it too tight.
July 7th, 2007 10:32 PM #4
what's the correct temperature of adjusting it? engine warmed up or cold?
Tsikot Member Rank 4
- Jun 2006
- 2,605
- Nov 2003
- 3,849
- Oct 2006
- 29
July 17th, 2007 06:38 PM #7Sir:
Naadjust din po ba ang valve ng corolla gli (1994)? Pinacheck ko kasi sa mekaniko malapit sa amin sabi nya self adjusting daw yun? (d ko po kc alam pagdating sa engines).
Medyo may ingay na kasi ang engine (tapping noise sa valve cover) lalo na pag bago start pag umaga? pero pag uminit, nabawasan na or after a long drive, pagdating sa destination , tahimik na din. Kaya kung minsan, pag dinadala ko sa mga reputable shops, hindi nila madiagnose ng maayos dahil tahimik na tahimik.
Wala din naman po usok ang engine, and the it performs well. Yun nlang po, medyo nakakainis at nakakabahala pag start sa umaga. Ano po ba causes nito.
Salamat po in advance.
BANNED BANNED BANNED
- Jul 2003
- 2,267
July 17th, 2007 10:03 PM #8gli model (4AFE engine)?
sabi din sa akin dati eh self adjusting pero i doubt it.
reading the manual, it doesnt say it is self adjusting. you can get it to the right clearance by putting new shims of the right thickness. but before you can do that, you have to do a lot of measurements. kinda complicated but i did it this way (better to download a manual first or visit autozone site). just to give you an idea.
do this when the engine is cold
set the crankshaft into top dead center then ID the valves you can adjust.
do it one pair of valves at a time if you have a 16 valve engine (i.e. intake of cylinder 1, etc.)
measure the gap/clearance using a feeler gauge. if the gap is within specs, then do nothing. if otherwise, you have to change shims.
thickness of new shim = thickness of old shim + (measured gap - specified gap)
this means, if ur measured clearance is larger than what is specified, you need a thicker shim for that valve (i hope i got it right)
besides a feeler gauge, you need a micrometer to accurately measure thickness of your shims. you also need a special tool to remove the shims under the cams.
if you are a DIY person, you can improvise. but you really need the extra shims.
what i did for my gl is i have a set of extra shims then by trial and error look for the right shim to install. if i need a thinner shim, i carefully grind the thick shims to the right thickness. took the whole day to to this. of course you have to do this to all of the valves.
find a mechanic who can do this as this requires a lot of knowledge and effort and patience.
- Oct 2006
- 29
July 18th, 2007 09:18 AM #9Last edited by pentium9; July 18th, 2007 at 09:20 AM. Reason: typo error
- Dec 2019
- 4
March 4th, 2020 07:53 PM #10
Kwento ng katrabaho ko, meron daw sya officemate dati na Italiano na tinanong daw bakit...
Traffic!
