Results 1 to 10 of 10
- Apr 2004
- 20
May 5th, 2006 06:06 PM #1its been a month na hinahanap ng mekanik ung vibration ng starex ko at 120km,until now dpdin makitakita.andun yung pinalitan ang ringer and pinion ng differential plus the bearings.axle bearings,after doing this result was nalipat yung vibration sa 100kms.try ulit pinalitan trans support kc may punit na,same w the bushings of the crossmember.nagpalit din ng centerbearing and 1 crossjoint but still ganun pdin.nag pa allign and wheel balance ndin ako wala pdin.help naman po dyan masakit npo tlaga ulo ko and also my bulsa as well!thanks po in advance to all!
- May 2006
- 913
May 5th, 2006 10:21 PM #3hav u changed the front wheel bearings? maybe the engine mounts nid to be replaced. or mayb the properller shalf is not ballanced.jst a tot.
May 6th, 2006 12:12 AM #5
May na-drive akong ganyang kotse dati, grabe vibration pagpalo ng 100 kph. Try mo pa tune-up, change plugs.
May 6th, 2006 01:33 AM #6
Nag-balance na ba kayo ng gulong? Harmonic vibration iyan since it does not occur at all speeds.
Tama ba yung pagpalit ng ring and pinion? Pat pagbalik ng driveshaft? Dapat tama backlash ng R/P, yung driveshaft naman dapat balanced (parang gulong). Baka lalo magkandaloko-loko kapag mga parts na ito na ang kinakalas.
- Apr 2004
- 20
May 6th, 2006 10:53 PM #7tenks 4 d replie!.ok naman po yung paginstall ng ringer and pinion ginamitan pnga ng mechanics blue para tama ang adjustment.ang sabi ng mekanik isang posibleng pinanggagalingan din daw nga is unbalanced propeller.or pwede din daw yung bushings sa may pwitan ng trans na para atang connected yun sa yoke.try namin this coming week ipabalanced propeller or check yung bushings sa trans.ok naman always naka tune up makina ko. maselan me sa sasakyan kaya alam ko d manggagaling yun sa untuned engine.nagpalit na din nga pala kami ng front wheel bearings.
May 7th, 2006 12:33 AM #8
rvm519 paki-post kung sakali mawala na ang vibration. Gusto ko rin malaman ang dahilan ng vibration na yan
Tsikot Member Rank 5
- Nov 2003
- 3,849
Traffic!
