Results 1 to 8 of 8
- Sep 2003
- 109
October 8th, 2003 05:15 PM #1Forgive my ignorance...
What is the best material to use for under coating?
Is the Rhino pick up bed material good for under coating? I asked about the material and it seems that it is everything an undercoating material should be... It protects from rust. It does not crack due to flex or heat. It does not chip. You can apply as thick a coating as you want. You can choose color to match your body color. It is good sound dampener. It is seamless when applied (meaning: no space between body and lining).
Being all of the above, why don't people use rhino material for under coating (aside from price consideration of course)?
- 10,620
October 8th, 2003 05:59 PM #2bosero, wag undercoat, malambot yun maski tuyo,
ma scratch lang din when loading.
October 8th, 2003 09:29 PM #3
Hmm...mukhang pwede nga kaya lang baka masyadong mahal or baka di pumayag ang installer.
October 9th, 2003 01:29 PM #4
I just asked tuff-kote if they are willing to spray the undersides of a vehicle with Rhino linings instead of their regular undercoating. And their answer is...no.
- Sep 2003
- 109
October 11th, 2003 12:02 AM #5Kimpoy,
Which is malambot? Rhino lining or under coating material.
What I want to know is why don't people use Rhino Lining material as undercoat material(aside from price considerations)?
Roydok,
I asked the same question as well, and their answer is also no. No, because they have never done it before.
I wonder why they have never done it before... is it because it is nobody has ever thought of doing it? Is is because it is impossible or difficult to do because of some application equipment limitations (does this need special equipment to apply or just a conventional spray attached to a compressor) ? Is it the properties of the Rhino material that prevents people from applying to the underside of the vehicle?
Can anybody enlighten me on this??? I am really curious why this cannot or should not be done.
Thanks.
October 13th, 2003 02:02 PM #6
there is a special spray gun and must use high compression air compressor that must be use on undercoat materials, ang ginagamit namin sa shop is wurth, pero mas prefered ko ang 3M, mas flexible ito kaysa wurth
- Sep 2003
- 109
October 13th, 2003 04:25 PM #7Rodcarolino,
So technically you can use Rhino Lining material if you had all the equipment??? In short, the reason why Rhino Lining is not used as undercoating is because of equipment limitation not a material limitation?
How much to have vitara undercoated?
Thanks in advance for the info.
October 13th, 2003 05:06 PM #8
pinaka-common ngyn yng wax-based undercoats like tuff-kote, 3m , wurth, bondo, etc.
i've heard mas maganda daw yung epoxy-based ones, kaso nga lang mas mahal. ano b yng brands na epoxy-based??
someones are (at last!) loudly asking, "why did they turn off the countdown timers?"
SC (temporarily) stops NCAP
